Thanks guys, got the same results on my C4. I was not sure I would get a better throttle response on the C5 with the ported mod.
Cya!
A ported throttle body should have about the same effect on any engine. As you have increased, and smoothed, bore diameter when porting, any throttle plate opening is now greater than the same throttle position prior to the porting. It's why response appears to be greater. I have heard claims of 5-10hp increases, overall, but, if true, am not sure if that would be seen on a stock engine. Overall power increases would only be seen if the stock throttle body posed a restriction at WOT, IMHO.
Ed
