zo6 wheels
Old Sep 6, 2006 | 08:11 PM
AndrewNguyen's Avatar
AndrewNguyen
Default zo6 wheels
i put 18" wheels all around 9'5 inches wide, the front fender gap is fine but the rear has over an inch if i lower just the back will it look funny
Old Sep 6, 2006 | 10:13 PM
AndrewNguyen
anyone it cant be that hard of a question right?
Old Sep 6, 2006 | 10:19 PM
Garrett W's Avatar
Garrett W
Pics would help
Old Sep 7, 2006 | 12:16 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Probably, but more to the point, how would it look to you? It's not a hard question, it's just that most people recognize the subjectivity of a response - makes it kind of worthless IMO.
Objectively, I wonder what would be the impact on the aerodynamics if you altered the rake of the car.
Old Sep 7, 2006 | 12:46 AM
AndrewNguyen
im just wondering what the others do that have the 18" all around, because in their pictures i dont know what they do but it looks real good, i know its lowered but do they lower the front and back because right now i barely have enough clearance for the wheel to turn
Old Sep 7, 2006 | 01:01 AM
wamara's Avatar
wamara
If you're running 18"s all around, and they are all the same 9.5" width, you need to stagger your tire size. If it were me, I'd run a 265/35-18 or 275/35-18 front tire, and a 275/40-18 or 285/35-18 rear tire.
What size is your front tire that you are so tight?
Old Sep 7, 2006 | 02:36 AM
Miguels's Avatar
Miguels
you would have to give up looks or $$ on this one.
I assume that you are doing this to rotate wheels correct?
The rake will affect your car and it will look awkward. I also assume that wider wheels is out of the question since I think you are tryng to rotate the wheels/tires.
Old Sep 7, 2006 | 10:41 AM
Wah's Avatar
Wah
Does this look like the rear has more gap to you ?
They are all the same size, 315/30/18. Yes, fronts and rears, mounted on the same size wheels, 18x10.5. And, no, I don't get any problem with Traction Control/ABS/Advanced Handling whatsoever.
Old Sep 7, 2006 | 11:21 AM
AndrewNguyen
i had 275/40/18 all around, but the thing is that i just bought new tires all around and i hate the fender gap in the rear.
To zo6 wheels
