Security goes on while driving...
Old Sep 7, 2006 | 07:47 AM
mcmtac14's Avatar
mcmtac14
Default Security goes on while driving...
Hello all,
This is a wierd one but I don't want anything really bad happening like the steering locking or the alarm going off while driving... the yellow SECURITY light goes on every once in a while while driving.
I have always pulled over right away and if I turn the car off and back on again it goes out... anyone know of this and is there a danger of something else happening like steering or alarm issues??
Thank,
mcmtac
Old Sep 7, 2006 | 08:32 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
This is a new one (at least for me).
Looking at your profile you have an '03 - so it should not be the FOB battery. However, does this occur regardless of which FOB you are using? If it only occurs with one of the FOB's, then more than likely it could be the battery.
I also see you have massive aftermarket sound system. Just a thought - maybe asking the guys/gals in the Audio Section if they have had similar issues can assist.
Let us know.
Old Sep 7, 2006 | 09:29 AM
mcmtac14's Avatar
mcmtac14
Hello AC54ME,
I am sorry but my profile was off a bit... I have a 2002 and so do not have a battery key fob... just the resistor in the key.
I also have pulled the Pioneer CD / receiver and put in an AVIC gps / nav... works great after all of the dash mods!!!
I will try the other key... It just started so I don't believe that it is related to the sound system...
Thanks for the comments!
mcmtac
Old Sep 7, 2006 | 11:40 AM
rob&dalevance's Avatar
rob&dalevance
I have the same problem, never been able to figure it out neither has the dealer, so I just do what you do when it happens. Pull over, turn her off, and turn her on!
Old Sep 7, 2006 | 12:23 PM
ytwokc5's Avatar
ytwokc5
I had this problem after my A/C leaked all over the BCM in the passenger footwell back in July!
I was able to resolve the issue by going through the BCM relearn procedure, search the archives it's been posted a few times in here.
Old Sep 7, 2006 | 01:00 PM
1965imp's Avatar
1965imp
This has happened to me too. I'm not sure I have solved the problem or not but it seemed like every time I locked the car with the lock button on the arm rest on the door this would occur. I only lock the car with the key fob. Try it,it worked for me.
To Security goes on while driving...
