Has anyone out there hardwired an Escort Radar Detector into the rear view mirror with a phone cord versus buying the Invisicord? Is it very hard or should I just go out and buy the Invisicord?
Thanks in advance
I hardwired mine into the Accessory oulet in the passenger floor panel, but I am using the Escort Remote. I like having the ability to silence the detector with the remote. I have the remote attached to the driver side of the center console with Velcro.
If I were going to hardwire into the rearview mirror, I would probably use the Invisicord.
If you wire it to the mirror it will still turn on & off when the car is off.
If the car is off and you open the door or trunk the radar detector goes through it's cycle. You have to turn the detector off every time.
That drove me crazy.
I ended up wiring an add-a-circuit to the fuse box in the passenger floorboard side. Run the wire up the pillar and across the windshield top.
I'm using an Invisicord with my Passport 8500 X50; my detector comes on only when I turn on the ignition key and shuts off when I remove the key (you need to make sure that you connect your cord to the correct wires)
I have an 04 Z w/electrochromatic mirror BTW.
You can easily make your own cord using plain old phone cord. You just need to get the correct size pins that will fit into the power mirror connector properly (too small of pins and the connections will be intermittent).
I believe CF member Shylor did this (as have others) and posted the P/N for the pins (that he purchased at Radio Shack). Might want to ping him or do a search.
I just preferred to buy a cord already made (to help support a great vendor) and be done with it
On my '03 I tried all the wires in the mirror and none were ign controlled. The only hot lead was connected to the timed light turn off system. Using a fused & dedicated circuit worked better for me.
cjs27410,
I've connected the Invisicord power to the BROWN wire (at the mirror power connector) and the Invisicord ground to the ORANGE wire (at mirror power connector).
Did you try this combo?
But it sounds like you've connected your detector another way and it works fine so that's all that matters
Larry
This along with the bracket from great lakes trophy is a winner.
I can't believe so many people just use the invisicord. That would drive me nuts. I hard wired mine with the Escort hard wire kit. Just find some +12 when the ign is on and your set. The wires could not be easier to run.
Larry
I had the same problem Larry on my 04. I use the Brown and Orange and it cycles when I open the door but it doesn't bother me enough to hard wire it to the BCM. Seems that some cars work differently for some reason. Maybe they changed the setup in 04?
i saw a thread awhile back about hard wiring the radar detector....it had a link to somewhere showing detailed instructions and pictures of where the acessory link is under the passenger side and everything....try a search and see if you can find it.....it might be helpful.....
Before you go through all this effort, you might want to review my experience. I have a 1998 with the "simple" rearview mirror. I could not get the mirror power to provide the ideal on/off scenario. YMMV.
Wow that's a bummer, sounds like maybe something was changed for 04
