manual shifting question
Old Sep 8, 2006 | 12:23 PM
drace99's Avatar
drace99
Default manual shifting question
I find that when I get on my 98 coupe, I seem to have a little bit of trouble going from 3rd to 4th. It seems to grind just a little bit. I was wondering if a short shifter would solve my problem or at least be smoother. Any thoughts?
Old Sep 8, 2006 | 12:27 PM
Tigershark3's Avatar
Tigershark3
Not likely...Sounds like a syncro issue. I'd change the fluid. Oftentimes the shifting is improved with just that. Worked for me.
Old Sep 8, 2006 | 12:29 PM
JD's C5's Avatar
JD's C5
Yep-this is the best advice and certainly the least expensive first effort. You would be surprised at how often this solves the problem.
wamara's Avatar
wamara
Cruise-In II Veteran
Syncros or maybe shift fork? In any event, try the easy stuff first and change the fluid.
Old Sep 8, 2006 | 12:35 PM
drace99's Avatar
drace99
Default changing fluids
Is changing the fluids easy, and what type of fluids should I use?
ie royal pruple or another synthetic?
Old Sep 8, 2006 | 01:11 PM
Mo'Phat's Avatar
Mo'Phat
Check your owners manual for the how-to. Any name-brand fluid will do.
Old Sep 8, 2006 | 01:32 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Go with Royal Purple Synchro Max
Old Sep 8, 2006 | 02:30 PM
frckid's Avatar
frckid
Actually it depends on the year. I think older C5's had the paper blocking rings which could be damaged by synthetic fluid.
Old Sep 8, 2006 | 02:31 PM
drace99's Avatar
drace99
Default Used car...no manual
sorry, I bought the car used and it did not come with a manual.
Old Sep 8, 2006 | 02:33 PM
02gt350's Avatar
02gt350
yup. change fluid first, as its the cheapest way to find out first. but a shifter will only make it worse i think.
Old Sep 8, 2006 | 03:36 PM
Old Sep 8, 2006 | 04:35 PM
NoelsTorchredZ's Avatar
NoelsTorchredZ
Syncro's, my old 97 started doing the same thing at about 45k miles. Had it rebuilt for a salty 2k
Old Sep 8, 2006 | 05:54 PM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
Hope for the best but expect the worst. Hope that the fluid change works but be prepared for a new/rebuilt transmisson since it sounds like the previous owner bent the shift forks banging/speed shifting it.
To manual shifting question
