99 C5 Overheating?
Old Sep 9, 2006 | 12:02 PM
GORDONJELLOW's Avatar
GORDONJELLOW
Default 99 C5 Overheating?
Have a 99 C5 with a Vortech Super on it.........temp runs 198/200 when rolling 20 mph and up....in traffic, stop and go after 5mins temp rises to 230 for a bit, then immediately drops down to 215/219 and stays ther till speed picks up and temp then drops to 200 again....is this too high?????????
Old Sep 9, 2006 | 12:04 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
It's a normal range but change the rad area to see if anything is caught and blocking the air flow
Old Sep 9, 2006 | 12:09 PM
Laguna Blu's Avatar
Laguna Blu
Stock radiator? Who re-programmed the car after the Vortech? I supplied my tuner with an aftermarket high capacity radiator while installing a Procharger. I also have a 170 degree T-stat & a Vinci fan controller which turns the fans on a bit sooner.
Old Sep 9, 2006 | 12:11 PM
GORDONJELLOW
Thanks Zilla for the good news...temp sounds OK, huh..whats with the sudden drop in temp when it hits 230? second fan coming on ?
Old Sep 9, 2006 | 12:12 PM
Gray Weasel's Avatar
Gray Weasel
Default overheating
Sounds like your radiator fins are full of stuff I just had my car 03 up on a lift and blow out the fins on both the air conditioner and radiator you would be supprised how much stuff comes out had a pile about 12" sq and 2" deep .....by the way now my car runs a lot cooler.... it now is on my list of things to due on a regular schedule.....you will need a long wand on the airgun but try this first before you due anything else you will be supprised the difference it makes
Old Sep 9, 2006 | 12:14 PM
GORDONJELLOW
Sonny Martell of Martell Racing in Manchester, NH did all the work.....stock radiator, was flushed during work.you run lower temps?????
Old Sep 9, 2006 | 12:15 PM
GORDONJELLOW
Thanks for the tip.........
Old Sep 9, 2006 | 12:30 PM
Laguna Blu's Avatar
Laguna Blu
Car should be ready next week....fingers crossed
To 99 C5 Overheating?
