signal problems
Old Sep 10, 2006 | 08:15 PM
grunz95's Avatar
grunz95
Default signal problems
Has any forum members have this problem. My signals work sometimes and other times they don't. I have a 99 coupe. I can turn on the right signal then the left and they will work. They I can try the left and it won't work. Then I repeat the sequence and they might work.
Thanks in Advance.
Gary
Old Sep 10, 2006 | 08:26 PM
VaTechHokie's Avatar
VaTechHokie
Hazard button more than likely the culprit
Old Sep 10, 2006 | 08:28 PM
billuvm's Avatar
billuvm
I have had the same problem before and would cycle the hazard button a few times to get the turn signals to work. Once i changed the hazard switch it has been fine ever since.
Old Sep 10, 2006 | 08:55 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Change the hazard switch, problem solved. This should help.
http://forums.corvetteforum.com/show...12&postcount=6
Old Sep 10, 2006 | 08:58 PM
indy300's Avatar
indy300
Easy to do and inexpensive. I replaced mine.
Old Sep 10, 2006 | 11:01 PM
Red73Vette's Avatar
Red73Vette
I had same problem. After four or six months, I live in Minn so it started last year and finally last month my battery died. I put in a new one and no problems since. Voltage of battery looked good but wasn't.
jerr
Old Sep 11, 2006 | 05:44 PM
C5 fury's Avatar
C5 fury
I have the same problem. When I reviewed the service manual, I noticed that the turn signal relays are housed in the hazard switch housing. I haven't replaced it yet, but if I turn on/off the hazard switch quickly, I can get it to work for a while.
To signal problems
