DRL Replacement Bulbs
Sep 12, 2006 | 10:49 AM
St. Jude Donor '07-'08-'09
Does anyone have the part number / bulb number for the Daytime
Running Light replacement bulb? It is Amber I believe.
Thanks.
Sep 12, 2006 | 10:56 AM
I believe it's a 33 or 3457. I replaced mine with the Silverstar 3157's
Hope this helps.
Derek
Sep 12, 2006 | 10:58 AM
Just did mine. Amber 4157.
Sep 12, 2006 | 01:08 PM
Derek,
What color light is produced by the Silverstar #3157 lamp?
If it is not amber is it still legal in all states?
Sep 12, 2006 | 01:43 PM
Thanks.
The DRL bulb GM part number is 12450182.
The bulb has a special high-tempature base to withstand the DRL heat. "Standard" bulbs will burn out quickly.
Good luck.
Sep 12, 2006 | 01:50 PM
The silverstar #3157 is amber cost about 13.00 at auto zone!
Sep 12, 2006 | 01:51 PM
From: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
How in the world does one change that thing?
Sep 12, 2006 | 01:56 PM
remove the black panels from the underside (5) 8mm screws
Sep 12, 2006 | 02:04 PM
Cruise-In VII Veteran
or pull the 3 screws from the headlight trim
Sep 12, 2006 | 04:29 PM
Derek,
It's lights up amber.
