Show your knobs.
Old Sep 12, 2006 | 01:26 PM
INTRUBL's Avatar
INTRUBL
Default Show your *****.
I have a Momo, Air Race Leather that is getting a little worn. So what's new out there.
Old Sep 12, 2006 | 01:33 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Not custom or anything... but my favorite by far. C6 Z06 assembly with a vette essentials short boot made for the C6 ****. I had a hurst for 3 years w/ every kind of **** out there.
Old Sep 12, 2006 | 02:07 PM
VetterGetIt's Avatar
VetterGetIt
Call me crazy but I like the large stock shifter, I think it looks good too.
Old Sep 12, 2006 | 02:24 PM
Lightgomez's Avatar
Lightgomez
I have the same one you do and it fits my hand just right!
Old Sep 12, 2006 | 02:25 PM
JD's C5's Avatar
JD's C5
Old Sep 12, 2006 | 04:42 PM
Rhode Warrior's Avatar
Rhode Warrior
This is what I have on my A4. You can't really see from the rear shot, but it's a pistol grip.
Old Sep 12, 2006 | 04:45 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I like that.
Old Sep 12, 2006 | 04:46 PM
chai1836's Avatar
chai1836
I like that a lot, how (or where) can I buy a similar setup? Did everything fit or did you have to mod it to fit in a C5?
Old Sep 12, 2006 | 04:59 PM
Cobra4B's Avatar
Cobra4B
^ Direct install... remove dash stuff, undo 3 torx bits holding shifter assembly in, then replace and re-bolt.
The cheapest place for the the shifter assembly is www.fredbeansparts.com I'd call them directly to order. Tell them you want a C6 S06 shifter assembly. It comes w/ the **** and everything.
And get the boot from www.vetteessentials.com Tell them you are using it for a C6 shifter so they'll give you the one that tucks right into the groove perfectly.
Old Sep 12, 2006 | 05:31 PM
chai1836's Avatar
chai1836
Sweet, thanks a lot!
Old Sep 12, 2006 | 05:43 PM
1-MEAN-VETTE's Avatar
1-MEAN-VETTE
5th Gear
kinda wierd.. but do u guys think this set-up (c6 assembly) will bolt right into my 01 Camaro SS?
Old Sep 12, 2006 | 05:53 PM
Tom/99's Avatar
Tom/99
[/QUOTE]
It works for me, so far.
Old Sep 12, 2006 | 07:57 PM
6 Shooter's Avatar
6 Shooter
...but I like the large stock shifter, I think it looks good too.
Old Sep 12, 2006 | 08:27 PM
EscapePod's Avatar
EscapePod
Well... since you asked:
Old Sep 12, 2006 | 08:35 PM
steve badalamenti's Avatar
steve badalamenti
This is the "Retro" look....
Parts are from a stock C-3. Threads are the same, and lockout fits right over the stem.
Shift pattern was removed from original ****, filed thin, and siliconed to console.
Old Sep 12, 2006 | 09:27 PM
TigerSharkVette's Avatar
TigerSharkVette
sparco with ripper shifter
Old Sep 20, 2006 | 07:12 PM
dsaxman's Avatar
dsaxman
To Show your knobs.
Old Sep 20, 2006 | 07:22 PM
502ci's Avatar
502ci
B&M Ripper Shifter, with a B&M smooth palm grip that I had to custom tap to fit the shifter.
Old Sep 20, 2006 | 07:31 PM
TJ VETT's Avatar
TJ VETT
Try Flameball.com
Old Sep 20, 2006 | 07:35 PM
TPR492's Avatar
TPR492
St. Jude Donor '06
Vette Essentials C6
