Battery trickle charge
Old Sep 12, 2006 | 02:01 PM
rwilkins's Avatar
rwilkins
Default Battery trickle charge
You can see where I'm from....PA....cold, snowy, road salt winters.. I won't be driving except on very nice (dry road) days in the winter... My question is; I understand you Corvette guys (Hey, I'm one too) put a trickle charger on your battery, due to many little draws on the battery while this elec. is talking to that. So, what kind should I buy and where?
By the way, I have a an old detached garage, and I wander if any critters will try to get warm in my baby? Besides mothballs, anything to discourage the little buggers? Thanks in advance.
Old Sep 12, 2006 | 02:41 PM
Joe C5 C2's Avatar
Joe C5 C2
Having spent most of my life just down the road from you in York I delt with the issues you mentioned. I used a small charger from Sears that was approx. $30 which worked fine. The key point is to get one that is listed as a "float" charger instead of a "trickle" type. This will prevent damage to your battery through overcharging (the float turns on and off automaticly). As for the critters I have heard people putting moth ***** in the car but I personally wouldn't like the odor so I just would put some rodent "feeding" packs found at the normal home centers around the perimiter of the garage and never had a problem in the cars. Good luck and hopefully it will be a mild winter.
Old Sep 12, 2006 | 03:04 PM
Floridasky's Avatar
Floridasky
St. Jude Donor '15
I use a Battery Tender on my Corvette for periods when I am driving the car and also on my Honda generator. One my Battery Tenders is about 15 years old.
Old Sep 12, 2006 | 03:07 PM
MYCoupe's Avatar
MYCoupe
I agree. Some type of "floating" charger, one of which is the Baterry Tender, is the way to go. I've used them for years on my motorcycle and cars and never had any problems.
Old Sep 12, 2006 | 03:48 PM
GrayC5's Avatar
GrayC5
As others mentioned above, you need a battery tender that switches the charge automatically to a float level so as not to overcharge the battery. Don't use a trickle charger for this purpose. Battery tenders (float chargers) are inexpensive and work quite well for keeping your car's battery properly charged.
Old Sep 12, 2006 | 04:36 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I did get a tender for winter storage. I purchased a Schumacher<S> for $16 at Wally world. (price in October last year) No probelmo.
I also have a bigger CHARGER by the same company for about 12 years now ,works good.
Old Sep 12, 2006 | 04:46 PM
Mike98SilVert's Avatar
Mike98SilVert
I use the Sears battery tender/charger as well. No problems
Old Sep 12, 2006 | 05:01 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
The VERY best trikle chargers have a feature called de-sulfating. Get one of those.
http://thebatteryminder.com/
Old Sep 12, 2006 | 07:43 PM
astvega's Avatar
astvega
i picked one up from wally world. small black and decker $16.
works good. it has led lights to let you know when its charging and when its not.
Old Sep 12, 2006 | 07:59 PM
T Will's Avatar
T Will
St. Jude Donor '13-'14-'15-'16-'17-'18-'19
We use downy fabric sheets for mice in the RV. Just spread them all around usually the whole box and in the spring your car will smell nice too.
Old Sep 12, 2006 | 08:02 PM
Carol & Lee's Avatar
Carol & Lee
Default Moth *****
Forget em, I have had a mouse use a sock full of moth ***** as a latrine. Use Traps baited with peanut butter (just a little) around the interior of the garage. If you have pets or small childern be very carefull of the poison packs. When a rodent eats that stuff they become poison. Like everyone states above get a float battery tender type.
Remember our young troops!
Old Sep 12, 2006 | 09:15 PM
silverbullit99's Avatar
silverbullit99
Should get one that turns on and off automaticly . As for the little pests,, you can also put some rags in the tail pipes,, I wouldn't put moth ***** in the car,, and have it smell like granny's linen box..
Old Sep 12, 2006 | 09:29 PM
ja03c5's Avatar
ja03c5
No need for a trickle or float charger in PA. Just take it for a drive on those nice winter days. I stored mine all winter and never had a problem, no charger.
Old Sep 12, 2006 | 10:14 PM
CHUXDRM's Avatar
CHUXDRM
Your question on chargers has been answered. . . some type of "float" charger. I also have the Schumacher from Wally, works great.
As for the little pests, I always used to put a couple boxes of the poison bait in the front corners of my garage, by Spring, they were empty, never seen the little devils, but assume the bait works. Last winter, I bought one of those high frequency emitting gadgets, sat it right under the Vette, this Spring, the bait boxes were still full. I assume the high frequency kept them completely out of the garage.
Old Sep 12, 2006 | 10:21 PM
HIRISC's Avatar
HIRISC
St. Jude Donor '06
Batter Tender Junior - waterproof version - love it
Old Sep 12, 2006 | 10:31 PM
vet4me's Avatar
vet4me
I live in Ohio,in the country.I use Bounce dryer sheets and a sears trickle charger.No problems
Old Sep 12, 2006 | 11:14 PM
rws.1's Avatar
rws.1
www.harborfreight.com
42292-1VGA
Chicago Electric Power Tools AUTOMATIC BATTERY FLOAT CHARGER on sale now
$7.49
These are 21st Century technology trickle chargers. They have a microchip that regulates the supplied amperage to exactly match the bettery drain, ensuring your battery is always at 100% full charge.
I have 2, my brother has 3 as well. We have had 3 Verts and 2 quads on these for the past two winters
To Battery trickle charge
Old Sep 12, 2006 | 11:17 PM
JC in XTC5's Avatar
JC in XTC5
Deltran Battery Tender Plus
Maintains the battery at the perfect charge - never overcharges it.
Old Sep 12, 2006 | 11:57 PM
I use a Battery Tender Plus for storing my car. Works great and is fully automatic.
Old Sep 13, 2006 | 06:34 AM
foremaw's Avatar
foremaw
St. Jude Donor '08-'09-'10-'11-'12
I had mice build a home deep inside the ventilation system on one of my other cars (Toyota) stored outside. The problem was I had left the HVAC vent system on fresh air instead of "recirculate" thereby leaving the venting system open. I'm no expert on the vette air duct pathways but I'd recommend storing it on recirculate to close off as much as possible.
