First Gear Problem
Old Sep 12, 2006 | 02:32 PM
Tinguindin's Avatar
Tinguindin
Default First Gear Problem
Hello;
One of the problems that I have noticed in my C5 is that when I try to start the car from first gear, it brings my shifter back (it bounces back to me). I was reading the manual and it does specify something like this.. Is this normal in a car? do I have to get used to it before I get it right.
Old Sep 12, 2006 | 04:08 PM
CVG323's Avatar
CVG323
sounds like stripped gears. my old prelude used to do that. correct me if im wrong guys, but that is defenitely what was wrong with me, does it jump out of gear during normal driving? like youre doing 45 in 3rd and all of a sudden BOOM i t shoots to neutral? if so then its the gears
Old Sep 12, 2006 | 04:10 PM
Tinguindin's Avatar
Tinguindin
No, all gears work fine, just # 1 is not working properly. It only happens when I start from rest.
Old Sep 12, 2006 | 04:47 PM
itchynackers's Avatar
itchynackers
I always found when that happens, that it was never fully in gear in the first place. Used to happen in my 2000 camaro SS alot. Happened a couple times in the Z.
Old Sep 12, 2006 | 04:56 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Originally Posted by Tinguindin
Hello;
That's pretty normal for all stck shifts, and is just the way it is and always has been.
Try to put it in first before you come to a complete stop.
Or, put it in third and then first. Never FORCE it. If worst comes to worst and you just NEED to go, drop it in second and feather the clutch a little more.
Best,
Old Sep 12, 2006 | 04:59 PM
Tinguindin's Avatar
Tinguindin
Thanks guys....
Old Sep 12, 2006 | 05:17 PM
Funn One's Avatar
Funn One
Check this out!
http://forums.corvetteforum.com/show....php?t=1465080
To First Gear Problem
