Torque Management
Old Sep 13, 2006 | 10:55 AM
jpsnyder's Avatar
jpsnyder
Cruising
Default Torque Management
Do you think this is a necessary evil needed to protect the automatic transmissions? Would a C5 corvette obliterate the transmission without any torque management program? What about those owners who do mods like a Maggie supercharger where acceleration comes on early. Does the torque management program work against the Maggie's 'early on' performance? Sorry, no answers, just questions?
john
Old Sep 13, 2006 | 10:58 AM
Ruz's Avatar
Ruz
I'm sure it serves a purpose...not like the engineers put it in just to rob the car of performance. I think its a personal trade-off...do you want a trans to last 100k miles with reduced performance, or do you want it to last 30-40k with better performance? (I don't know how long a trans will last if you remove TM, just giving examples.) Could you imagine the outrage if they didn't have TM and everyone needed to rebuild their trans after 30K?
Old Sep 13, 2006 | 09:27 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It is there to prevent heat. If you got on the car at every light then it would only last about 20k. But since most people get the 6/60 it would make sense for GM to...
1. Get a better, stronger auto trans, which costs more money.
2. Install a cheap program in the car and save money and save warranty work.
IMHO
Old Sep 14, 2006 | 05:47 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I had mine deleted for quite some time before I had the maggie installed... I thought it was a different car! ran flawlessly
I've had the maggie now, going on 8 months... no issues, just clean off the line torque....
Dave
Old Sep 14, 2006 | 06:14 PM
Vette_Fan's Avatar
Vette_Fan
Dave
Instead of deleting the TQ Managemnt, couldn't you just turn off the Active Handling/Traction Control = and achieve the same thrill. With turning off the switch, you can always trun it back ON, when you need to. I'm not sure if there would be any difference in these two situations.
Old Sep 14, 2006 | 06:16 PM
InSaNeKaMeL's Avatar
InSaNeKaMeL
TQ Managemnt is not Traction control...
Old Sep 14, 2006 | 06:19 PM
Mike Mercury's Avatar
Mike Mercury
No.
You're confusing torque management with one of those other two systems.
Torque Management for the A4 is the retarding of ignition timing during a shift. From the factory, TM is active
no matter what mode you are in.
To Torque Management
