LED turn signal lights
Old Sep 14, 2006 | 04:31 PM
78-Bandit's Avatar
78-Bandit
Active Streak: 90 Days
Default LED turn signal lights
I want to convert my front markers to LED. Currently I have to remove my intercoolers to change bulbs, so I want the long life. Has anyone done this. The LED web sites say I may need to add load resistors, and/or an electronic flasher unit. DO I need either? I just want to make sure I buy all the parts I need. I have a 2001 vert
thanks
Old Oct 1, 2006 | 02:53 PM
tommybilt's Avatar
tommybilt
You can just pop out your front 3157 bulbs and add the LEDs however they will now flash in hyper mode like when a bulb is out. pretty ghey if you ask me. or you can slice in some resistors...
Old Oct 2, 2006 | 09:44 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
thanks
You will need a 6 ohm resistor to avoid the hyper flash syndrome. You have a pm.
To LED turn signal lights
