Installing Catback exhaust - have question
Old Sep 14, 2006 | 10:37 PM
Dave1998's Avatar
Dave1998
Default Installing Catback exhaust - have question
What is your experience reusing the gasket between the factory H pipe and factory mufflers when installing the aftermarket mufflers ?
If I start this project, should I buy new gaskets?
If yes, from where?
Thanks Dave
Old Sep 14, 2006 | 10:39 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
If yes, from where?
Thanks Dave
If you are starting it, replace them. If you already have it apart, no big deal to reuse. I have had my exhaust off many times without replacing. No problem at all....
Hope that helps...
Old Sep 14, 2006 | 10:45 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
When I changed my exhaust I got new gaskets from either AutoZone or O'Rileys.
Old Sep 14, 2006 | 11:10 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Not a problem if you don't change it, but then again, why not.
Old Sep 14, 2006 | 11:39 PM
4DRUSH's Avatar
4DRUSH
Get new ones in case the old ones are stuck to the flange and tear during disassembly. Apple Chevy sould have them.
Old Sep 15, 2006 | 06:50 AM
When I had my cat back installed, it just reused the original gaskets. No leaks at all. If the gasket looks OK after taking off the stock exhaust, you should be OK.
To Installing Catback exhaust - have question
