low oil on DIC?
Old Sep 15, 2006 | 01:46 PM
02gt350's Avatar
02gt350
Default low oil on DIC?
got a low oil light on starting it yesterday. drove it a while so it was hot. i checked the oil and it was about 1/8 inch below the hash marks on the dip stick. when i t was cold it was at the bottom of the hash marks. i just got an oil change 1500 miles ago and its not burning nor leaking. is this a common prob or am i really low on oil?
Old Sep 15, 2006 | 02:35 PM
VetteLag00's Avatar
VetteLag00
Usually the low oil level warning is on the money
Old Sep 15, 2006 | 02:49 PM
thisMSGgood4me's Avatar
thisMSGgood4me
If you're just below the hash marks, then add half a quart. Maybe you didn't get a full fill when the oil change was last done. Check it again after another 1500 miles.
Old Sep 15, 2006 | 03:14 PM
Jackal's Avatar
Jackal
Beware the low oil warning on your DIC. I spun a rod bearing while ignoring a speradic low oil warning.
Old Sep 15, 2006 | 03:15 PM
JoshVette's Avatar
JoshVette
Yup, this happened to me once and I checked it, barely low, so I just added a 1/2 and it never came back.
Old Sep 15, 2006 | 03:27 PM
waupachino's Avatar
waupachino
It sounds to me when they did the oil change they didn't put the full 6.5 quarts of oil in.
Old Sep 16, 2006 | 11:19 AM
asby69's Avatar
asby69
I had the Low Oil pop up a couple of days ago.......needless to say I freaked out..
I immediately stopped and checked the oil. It was right on full. So I waited a few minutes and checked a few more times. Still on full, so I'm thinking WTF?!?!
Anyways, got back in started it up and drove on....hasn't came back on yet.
Wierd huh?
Old Sep 16, 2006 | 11:54 AM
steveblonde's Avatar
steveblonde
i have seen that before - not with the vette but another car, my mothers car they once forgot to tighten the filter properly and it leaked, and on one other occasion they forgot the oil completly. good job it was a Mustang anyway they bought her a new motor after a BIG hassle . so in short check the filter to make sure its not leaking -or they may have shorted you a bit
Old Sep 16, 2006 | 01:20 PM
cuzzman's Avatar
cuzzman
I have had it happen before (as mentioned above) where the dealer doing the oil change just didn't put enough in when they did the change. I added a quart (yes they had miscounted by a whole quart) and watched my oil level closely for the next 1500 miles or so and it never moved.
Old Sep 16, 2006 | 01:28 PM
ja03c5's Avatar
ja03c5
I had a bad sensor at one point. Check that out.
To low oil on DIC?
