[Z06] Clutch fluid change
Any help would be appreciated.
I have not tried bleeding the clutch on my '03 Z yet. But I have changed the fluid in the reservoir several times. From what I understand, without a remote bleeder installed, it is almost impossible to bleed the clutch as you can't get to the bleed valve. If you figure out how to get to it from the bottom or the top, please post, with a picture if possible.
Clutch Pedal Woes--Fluid Impact
Clutch Hydraulic Fluid--the Chevy Spec
Clutch Pedal Woes--Fluid Changing Kit
Ranger
This is the easiest job there is on the car. It is even easier than opening the car door, sitting in the driver's seat, finding the key hole on the dash and putting the key in. You want it step by step, here it is.
1. Open the hood of the car.
2. Find the clutch master cylinder (it's that black cap in the corner of the engine compartment by the driver's door -- next to the brake master cylinder reservoir which is the white-ish container with the black cap).
3. Put some paper towels or rags around so you don't get fluid on the paint. (brake/clutch fluid eats paint, so be very careful).
4. Remove the cap and the rubber bladder if it doesn't come out with the cap.
5. Wipe the part of the rubber bladder that contacts the fluid clean.
6. With a syringe, turkey baster or other suction device, suck as much of the fluid as you can out of the reservoir. (dispose of the fluid properly -- it's brake fluid, toxic and it eats car paint).
7. With a clean paper shop towel, wipe out the inside of the reservoir. If you can't get all the crap/dirt out, pour in a little fresh brake fluid and wipe it out again.
8. Pour in fresh brake fluid up to the fill line (about mid-way up the reservoir). Do not overfill or it will overflow when you put the bladder back in. Tap the line below the reservoir or the side of the reservoir a couple of times to release any potential bubbles of air in the line.
9. Reinstall the bladder, put the cap on and tighten gently by hand.
10. Pump the clutch pedal a few times to be sure you have good pedal feel, and check the reservoir to make sure you are not leaking any fluid.
11. Close the hood, start the car and go drive the car and have fun.
Simple as can be.
BTW, if you have not changed the fluid in a long time, the fluid in the clutch line will be rather dirty. You might want to do this procedure a couple of times over the course of a month or two to assure that the fresh fluid is getting down into the lines and to get as much of the dirt out of the system as you can. After that, maybe once in the spring, once in the fall, unless you are tracking the car, in which case I'd do it before each track event.
Thanks for all of the information - it was very easy.
