As determined by the help of a forum member I need to undo the generals fix before installing CLB. Reading through several post I need to bypass dealer installed relay and apparently jump wiring on BCM on pins 30 and 87(orange and white wires). My problem, not an electrical guy, need help identifing said relay and how to bypass and how to identify above mentioned orange and white wires and how to jump.
Any and all help appreciated, Thanks
I just installed a CLB in my 2000 coupe and had the K harness relay. Based on the fact that I had white, black, green and purple wires on both sides of the steering column harness that tells me I had both relays mods done. I see the K harness that is disabled with the CLB but I also cannot locate the other relay. I have been searching for help in that area. I have heard its under the BCM but it is not there for me. I would happy to help you locate yours. Today the weather is not really Vette driving weather though...
it's located just above your BCM under the passenger footwell. there will be two relays. The one on the right will probably be the one. Check for wire colors. Two orange wires, white, purple, and dark green.
