[Z06] Low oil question
Old Sep 16, 2006 | 04:04 PM
kbreese's Avatar
kbreese
Default Low oil question
I have an 01 Z06, just curious if it runs low on oil will the DIC tell me so?
Old Sep 16, 2006 | 04:29 PM
kbreese's Avatar
kbreese
I know how to check the oil with the dipstick. That wasn't what I was asking. But thanks for attempting to help me
Old Sep 16, 2006 | 04:46 PM
Arfboy's Avatar
Arfboy
Yes, it will. And it'll keep telling you until you add more. Happened to me last week.
Old Sep 16, 2006 | 04:55 PM
kbreese's Avatar
kbreese
Well I guess my 01 doesnt really burn much oil b/c I go like 4k miles between changes (only had 1 change so far and do for 2nd another 1500 miles) and so far its never come on.
PS-it autmatically comes on and takes over display right? meaning regardless of what you have on display it will pop up, right? You don't have to actually scroll to a specific function to see it do you?
Old Sep 16, 2006 | 04:58 PM
Arfboy's Avatar
Arfboy
Yep. It'll just pop onto the display and stay there until you hit reset. Then it'll come on again whenever you start your car again until you add more oil.
Old Sep 16, 2006 | 05:07 PM
Z06-Nomad's Avatar
Z06-Nomad
I think it would have to be really low before it warns you. I think most of the guys around here would eject you from the Corvette community if you routinely waited for that light to check your oil
And yes, the warning should over-ride whatever is in on the DIC.
MD
Old Sep 16, 2006 | 05:19 PM
kbreese's Avatar
kbreese
Well I would think GM would set it to read at a point where it starts to become a possible hazard and no lower than that. They certainly don't want to have to replace engines under warranty.
Old Sep 16, 2006 | 11:25 PM
tcal95z's Avatar
tcal95z
my 01 Z warning comes on right at 1 qt low
Old Sep 17, 2006 | 12:03 AM
kbreese's Avatar
kbreese
Thats what I figured, Thanks for confirming. Unless the DIC is dysfunctional than it will most certainly let you know when oil needs to be added.
Old Sep 17, 2006 | 09:31 AM
bmacZO6's Avatar
bmacZO6
It was a legitimate question and worth asking. It is nice to know it will tell you when you are a quart low.
Old Sep 17, 2006 | 09:54 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Play nice in the sand box guys......
NO Personal attacks/hostility toward others, its a rule
The ones that had posts deleted would do good to go read the rules....
http://forums.corvetteforum.com/show....php?t=1118172
http://forums.corvetteforum.com/forumdisplay.php?f=109
http://forums.corvetteforum.com/show....php?t=1324902
IF you have further issues......take it to PM or e-mail, also a rule above
To Low oil question
