Service Column Lock ?
Old Sep 19, 2006 | 10:50 PM
redrocket87's Avatar
redrocket87
Default Service Column Lock ?
Today jump in, start and DIC says to remove key for 10 seconds. So I do, put key back in start and says SERVICE COLUMN LOCK. SHOOT! So I try to turn the wheel and nothing, no go its rock solid. I remove the key and try again... no problem what so ever, I'm off to the races.
Ideas? Have no idea if the previous owner had the locked serviced or not. Thanks guys for your input.
Old Sep 19, 2006 | 10:54 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Buy a CLB kit and install it ASAP!
Old Sep 19, 2006 | 10:59 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
$50 to buy clb and easy to install. One less thing to worry about!
Old Sep 20, 2006 | 08:22 AM
redrocket87
Thanks but still have questions.
How can I tell if the prior owner already took care of this?
Is it common for the column to lock, take out key and clear the problem?
Old Sep 20, 2006 | 08:36 AM
Rhode Warrior's Avatar
Rhode Warrior
Check your battery and connections. That will sometimes cause it.
Old Sep 20, 2006 | 09:22 AM
Blueleader's Avatar
Blueleader
Read thru the "Steering Column Lock FAQs", also when this happened to me, I pulled the two fuses out (in the sticky) and was just fine after reinstalling them. I have the CLB from Corvettes of Houston for installation if it gets out of hand but hasn't happened again in 9 months. Check the fuse box on passenger side and look for corrosion as water can slip in from the battery compartment when you wash your baby. Did you have a low battery lately or is your battery a bit old? This will cause the warning.
Old Sep 20, 2006 | 09:39 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
If your steering wheel locks you obviously don't have the latest recall performed on your car. The latest recall entails the steering column lock plate removed and also a K harness installed, which has proven to be defective.
You'll need to get your steering column unlocked first, then install the CLB and don't take your car back to the dealer for this issue.
Old Sep 20, 2006 | 09:59 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
http://forums.corvetteforum.com/show....php?t=1015483
Read all of this, it's long but should answer all of your questions. The most famous problem these C5 have.
Old Sep 20, 2006 | 10:23 AM
wamara's Avatar
wamara
Cruise-In II Veteran
I've also read other peoples' remarks to the effect that they have it on hand, keep it in their glovebox, etc., in case the problem arises. Maybe it's just me, but I don't get it. Having recently installed my CLB from COH (works perfectly BTW), this is not something I'd want to be doing in haste, late at night, alone in a parking garage, while it's raining, and so forth. And Murphy's law tells me the problem will strike at the most inopportune time....
While not hard per se, if you haven't done it before and are not familiar with the procedure, you'll want to take your time, so as not to break all those little plastic parts and pieces. I also needed a trouble light to see things clearly.
Old Sep 20, 2006 | 10:42 AM
Tact's Avatar
Tact
"Get 'er done"
Old Sep 20, 2006 | 12:19 PM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Turn the ignition key off and take the key out. If you can turn thr wheel about a full half turn or more you have the CLB already installed.
If not get it and install it.
Old Sep 20, 2006 | 01:48 PM
sgreen4067's Avatar
sgreen4067
i just don't understand.. there is 100000 of post about the clb and people still post the same old questions... what gives....
Old Sep 20, 2006 | 04:13 PM
skipsville's Avatar
skipsville
From: Mtns of north Georgia - Hey Kids, I'm spending your inheritance!
.........How can I tell if the prior owner already took care of this? ..............
Send me the last eight numbers of your VIN and I'll check it for you.
Skip
To Service Column Lock ?
