What are Corvette’s made of? Fiberglass, Composite, combination of both or what?
Steel frames (except for the Z, which are aluminum and some other exotica); composite bodies. GM left fiberglass behind some years ago for the Corvette.
It's still fiberglass, e-glass, not even s-glass, just made differently and with a different resin. I believe they also use a special continous strand layer on the outside to get a smoother finish. It's called sheet molded compound because they maked preimpregnated sheets of fiberglass then store them chilled and wet to use later. At a later time they cut them into the right shapes, stick them into a mold and bake it.
Uh... NO. I assume by Z you mean Z06, if so it's frame is made of the same old plane Jane steel as it's C5 brethren. Perhaps you are thinking of the titanium exhaust on the Z06?
