Check Engine Light - Twice a Month?
Old Sep 22, 2006 | 07:45 AM
garymilgrom's Avatar
garymilgrom
Default Check Engine Light - Twice a Month?
My check engine light comes on every few weeks. It's always some dumbass code that means nothing. I've started ignoring the light, even considering a Car Talk solution like black tape over the damn thing.
Does anyone else have this problem with the car throwing a lot of codes?
My car is a 2001 coupe. Thanks gm
Old Sep 22, 2006 | 07:55 AM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
what code? You know you can read and clear codes thru the DIC right?
A recurring code = problem.
Old Sep 22, 2006 | 08:21 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You would help us help you a lot better if you would click the following link and follow the instructions to determine what code the car is setting that is causing the light.
http://97vette.com/howto/codes/index.html
Post back to this thread with what you find. Hopefully it is something minor and we can help you get it sorted.
Paul
To Check Engine Light - Twice a Month?
