early this morning, while visiting a friend, some jerk broke in my car and stole my ipod and radar detector! only thing is i cant figure out how they got my door open? i know my door was locked because my alarm was going off! there are some slick people in this world, if ur ever in the area of memphis tn, be careful because we have some rogues in this city!!!
Easy to get in. A coat hanger is one way I have gotten into several cars.
From: I speak the truth. Harsh but accurate. The Woodlands Texas
St. Jude Donor '09-'10
All you have to do is pull the top of the window out. You can reach in with your hand and hit the unlock button. You would be suprised how far the glass can move out. Take a good look at your glass and see if it is full of prints. I saw a goober at work do this after he locked his keys in his 2002 coupe.
yep... I had to get into a C5 that a porter locked the key's in... I just used a tool called an inflate a wedge, to gently pry back the window enough to use a spare antenna to pop the door lock.. took less then a min to get into it.. yes it will set off the alarm.... now for a theif probably could just pry it with anything an be rough with it and do the same thing.. it's not hard... people lock keys in cars all the time if you practice a few times you can do it real quick and if you can see everything you want in the car it just takes a couple seconds to ****** it..
-=Rick
