License Plate Mounting
Old Sep 25, 2006 | 01:52 PM
bonnell's Avatar
bonnell
Default License Plate Mounting
Hi,
I just recently purchased my '02 vert and today I went to mount my new plate and found that there were no mounting screws. Off to Walmart and I purchased a simple package by the license plate frames. These are screws with machine type threads.
These look to be corerct but will only screw in about 1/4 inch. Meanwhile I noticed that the plate frame is made to snap apart and hold the plate. So, I put the plate in and snapped it back together. I do not like trusting just plastic so I inserted one screw as far as it would go.
1) Do you use the plastic frame and no screws?
2) Can you tell me the correct screw size?
TIA
J
Old Sep 25, 2006 | 02:14 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Use screws. The plate is cosmetic only. I don't know the size of the screw. If no one else chimes in, I'll check it when I get home from work.
Old Sep 25, 2006 | 02:19 PM
sailohio's Avatar
sailohio
The screws GM uses have a courser thread than normal machine screws. I know my Audi uses a smaller machine screw. You want to get the correct screws and put both screws in. I got some chrome caps to go on top of the screws and it makes for a much cleaner look. I got them from an auto parts store like Nationwise. Also, I put the Kewl plate frame which is painter to match my car. I think it looks almost as nice as no plate. It's too bad we have to have a front plate in Ohio.
And welcome to the forum.
Old Sep 25, 2006 | 02:48 PM
bonnell's Avatar
bonnell
Thanks Cozmo. I will try to get by an autoparts store today.
Old Sep 25, 2006 | 02:50 PM
bonnell's Avatar
bonnell
Thanks SailOhio! This is a really good forum. There is so much activity and so many posts of all sorts that using the search function (as suggested) usually returns answers.
Old Sep 25, 2006 | 03:04 PM
waupachino's Avatar
waupachino
I assume you are talking about the rear plate, I do not have any screws holding my plate in. I just used the frame and it has been like this for over a year with no problem.
Old Sep 25, 2006 | 05:08 PM
Ron Dittmer's Avatar
Ron Dittmer
ALL MY CARS, Corvette or otherwise.....
I get all new license plate mounting screws from ACE Hardware.
- Flat Blade
- Pan Head (low profile)
- Self Tapping
- Stainless Steel
The low profile pan head screws are clean and never rust.
I learned years back from an old 1987 Taurus we had, when my son tapped the rear of another car. The stock license plate screws pierced the bumper skin of the other car causing $400 damage that would have been $0 with the low profile panheads.
It also saves our clothing and skin when we walk around the car in our garage. Those stock license plate screws are so very sharp, stick up high, etc.
I do realize the stock Corvette screws are low profile. At least in the back. I don't mount a plate up front.......though by law I should.
Old Sep 25, 2006 | 05:14 PM
I use both the license plate surrounds and the screws to hold the plate in.
Old Sep 25, 2006 | 05:38 PM
Mr.DJ's Avatar
Mr.DJ
On our rear plate/frame, I utilized four 1/4"x1" anti-theft license plate fasteners (special allen-head machine screws) from Cruiser Accessories ( www.cruiserframes.com ), which I purchased from my local Kragen Auto Parts store. I also purchased a set of AutoLogic license plate fasteners which came with black plastic decorative screw head cap covers. These covers snap onto a retainer to cover the screw head, and which I used on the anti-theft fasteners to match our black license plate frame on the C5. I utilized the same, but with chrome covers, on our new Chrysler as well.
Old Sep 25, 2006 | 07:24 PM
bonnell's Avatar
bonnell
Thanks for the replies! I was able to find a kit at O'Rielys. They are 1/4" and black so they look good with my black paint and frame.
Old Sep 26, 2006 | 08:21 AM
Midwest Vette's Avatar
Midwest Vette
Me too.
To License Plate Mounting
