Rats In The Hood
Old Sep 25, 2006 | 11:21 PM
Quikturn's Avatar
Quikturn
Default Rats In The Hood
This is too funny! This happens only when you Assume. Took the Vette to the Dealer, all three warnings came up: ABS needs servicing....Traction Control needs servicing...Active Handling needs servicing....anyway, to make a long story short, the ABS braking Module had to be replaced. Thank God I had an extended warranty, the cost alone for the part was $1500The following month I was low on washer fluid, went to do a re-fill and noticed that the resevoir tank had a hole in it, and washer fluid was seeping out. I assumed the tech that did the work on the ABS Module, must have slipped with whatever tool he was using, and burned it. Actually there were two holes in it. Lol and behold, we discovered rat turds!!!!! Those damn rats under my hood eating my corvette!
Old Sep 25, 2006 | 11:24 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
That's just
Old Sep 25, 2006 | 11:48 PM
jrose7004's Avatar
jrose7004
Geez!
Old Sep 25, 2006 | 11:56 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
samw thing happened to my buddies porshe, hope the liuttle buggerg drown in washer fluid, or at least learned their lesson
Old Sep 26, 2006 | 12:02 AM
MUKAK's Avatar
MUKAK
Originally Posted by jrose7004
Geez!
luiz
Old Sep 26, 2006 | 01:37 AM
Virtual Geezer's Avatar
Virtual Geezer
Old Sep 26, 2006 | 08:40 AM
deemer's Avatar
deemer
Here is how to keep the rats and any other rodents from inside the car, under the hood or just plain out of your garage. Use moth *****!! In the garage, just put them under the car or around the walls. Inside the car or under the hood, get a pie plate or some other device to hold the moth ***** in (do not put them directly on the carpet). Then simply put the pie plate on the engine or on the floor. It really works!
Old Sep 26, 2006 | 09:34 AM
Hope you get rid of them soon - those pesky critters will do some real damage otherwise. Once they get into the wiring, things will get expensive.
Old Sep 26, 2006 | 09:50 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Squirrels too, I had them get under the intake manifold on my truck and chew the knock sensor wiring.
Old Sep 26, 2006 | 10:02 AM
sailohio's Avatar
sailohio
I've had mice build a nest in mine, but RATS?
Old Sep 26, 2006 | 11:25 AM
b98's Avatar
b98
Rats, time to clean up your act.
Old Sep 26, 2006 | 01:27 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
You don't drive your car enough
Also, you might want to try installing one of those electronic rodent repellants in your garage.
Old Sep 26, 2006 | 02:44 PM
edensknight's Avatar
edensknight
Holy ****! Well, I better go check mine!
Old Sep 27, 2006 | 10:34 PM
Quikturn's Avatar
Quikturn
The Rats are eating good! The dcon stuff is slowly disappearing! So disgusting
Old Sep 27, 2006 | 11:05 PM
hawkrob's Avatar
hawkrob
I had the same thing happen in my old camaro, had to pick out cooked baby mice. Mothballs remedied that problem..
Old Sep 28, 2006 | 12:15 AM
Mr.DJ's Avatar
Mr.DJ
Well, it appears that your local rats switched from a 'garlic only' diet.
To Rats In The Hood
