Removing Sticker Question
Old Sep 26, 2006 | 06:00 PM
JohnnyFast's Avatar
JohnnyFast
Default Removing Sticker Question
I have a black "racing" sticker on the back of my C5 that I would like to remove. Do I simply have to heat it w' a hair dryer and peel? Will this leave any type of marks?
Old Sep 26, 2006 | 07:21 PM
Hrdtop00's Avatar
Hrdtop00
After you heat the sticker and peel it off, use "Goop Off" to remove the glue residue. You can pick it up at Walmart. I've been using it to remove county stickers & Carlisle Fun Display sticker glue for several years. Works great! I'm sure there are other products out there, but this stuff works.
Wayne
Old Sep 26, 2006 | 07:25 PM
JohnnyFast's Avatar
JohnnyFast
Thanks Wayne, I'll give that a shot!
Old Sep 26, 2006 | 08:43 PM
silverbullit99's Avatar
silverbullit99
Wayne
Here we have Goof off.. probably the same thing.. works great. Remember, the cleaner removes the wax as well so
after it's all cleaned off give the area a coat of wax...
Old Sep 26, 2006 | 09:20 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
What colour is the vette?
Just hope the sticker hasn't been on the car long because if it has there may be fade.
Old Sep 27, 2006 | 12:33 AM
A hair dryer should work to loosen the adhesive and let you remove the sticker. You can also use WD40 to remove any remaining adhesive. Then rewax.
To Removing Sticker Question
