[Z06] Clanking Sound When Shifting Hard
Old Sep 28, 2006 | 03:17 AM
CodeName Z06's Avatar
CodeName Z06
Default Clanking Sound When Shifting Hard
I have an '02 Z and when i change gears and release the clutch to quickly i can hear a slight clanking sound coming from under the shifter area maybe towards the front of the car a bit. If i switch gear while pulling the clutch out smoothly there is no noise, i have 28000 mi on it.
Any i should be worried about, or ideas it can be, hoping its not the drive shaft. Thanks.
Old Sep 28, 2006 | 05:35 PM
CodeName Z06
Anybody, do any of you guys hear a noise when shifting?
Old Sep 29, 2006 | 09:45 AM
rickvette's Avatar
rickvette
Default 2001 Clanking Sound
My 2001 Z has always had some driveline "clanking" Especially noticable when you do an rapid clutch engagement. This is a combination of clutch and transmission play and I've learned to live with it.
Old Sep 29, 2006 | 12:09 PM
CodeName Z06
Good to hear at least i am not alone.
So its just another one of those corvette noises you need to live with?
Old Sep 29, 2006 | 12:15 PM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Sounds like typical drive line slack
To Clanking Sound When Shifting Hard
