Help!
I have a 2004 vert. The passenger side mirror is fine.
The drivers side mirror shakes so bad while driving that I can not see behind me while driving at highway speed.
I took it into my local dealer. They replaced the drivers mirror and it is just as bad, if not worse than the orignal one.
Any suggestions?? Has anyone else had mirror shaking problems??
Neatnic
I know with my Explorer I had to replace the driver's side mirror and had the same problem. I did not buy it directly from Ford, but it said it was a direct "replacement" that looked and fit the same as the OEM. I probably should have known though that the $50.00 price difference meant something.
Do you think they replaced yours with a "replacement" mirror instead of an OEM Mirror??
No, they ordered a new mirror for GM and had to have it painted also. It matches great... to bad it shakes also.
I called the dealer back and they are going to check for GM bullitains on it.
First problem I have had with my 2004.
I've got a '04 coupe and have the same problem. Dealer replaced the mirror and it doesn't shake as bad, just haven't had time to go back to dealer about it.
