Fog Lamp Bulb Replacement
Old Sep 28, 2006 | 02:08 PM
Spark 2's Avatar
Spark 2
St. Jude Donor '07-'08-'09
Default Fog Lamp Bulb Replacement
Has anyone noticed any negative effects from switching to the brighter
50 Watt #885 bulbs. Can the highter temperature cause any problems
with the wiring or the housing itself?
Thanks for your input!
Old Sep 28, 2006 | 02:12 PM
patton's Avatar
patton
St. Jude Donor '09
when one burned out i was gonna put bigger wattage in but whimped out when i saw how small the housing was. i thought heat may be an issue
Old Sep 28, 2006 | 07:02 PM
rws.1's Avatar
rws.1
I have used the 50 watt #885 bulbs for over a year now will no ill effects.
Old Sep 28, 2006 | 07:05 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
I used the brighter bulb before the PIAA lights with no problems.
Old Sep 28, 2006 | 07:38 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
I've used them for about 2 years with no problems
Old Sep 28, 2006 | 07:41 PM
Oldvetter's Avatar
Oldvetter
I have used them for over three years (I always use them with my low beams) with no problems. One bulb had to be replaced.
Be sure to re-aim them, factory setting is way too low.
To Fog Lamp Bulb Replacement
