[Z06] shifter questions
Old Sep 29, 2006 | 01:01 AM
DEEPWEE's Avatar
DEEPWEE
Default shifter questions
fairly new here so sorry for any stupid questions. have had my 02 z06 for about 3 weeks now and i hate the stock shifter. have read many threads abouts various shifters and lately about the c6 z06 shifter on the c5's. now i would like for you all to compare the c6 zo6 shifter to a hurst.
thanks
Old Sep 29, 2006 | 08:25 AM
fasthwks's Avatar
fasthwks
I just went from a B&M shifter to the c6 zo6 shifter and love the change. The ripper was short but a little to notchy for me, I guess if I tracked the car all of the time then it would be good but it was just too stiff and very noisy. The c6 shifter is stock feel with a little shorter throw. If you are expecting a huge difference than it is not it but it works great for daily driving. If you do a search this has been discussed alot and there is many different opinions when it comes to shifters. Good luck.
Old Sep 29, 2006 | 08:53 AM
RAMMAN's Avatar
RAMMAN
Pro Mechanic
St. Jude Donor '16 thru '26
I looked at the C6 Z06 shifter it feels like it’s a little too sloppy to me still. What’s the difference in feel between the Hurst and the B&M?
Old Sep 29, 2006 | 08:56 AM
Matt69-ZO6's Avatar
Matt69-ZO6
I had a hurst in and could not get rid of the rattle....Replaced it with a Breathless Performance shifter and love it! It is stiff into 5th and 6th, but otherwise a great precise shifter....
Old Sep 29, 2006 | 09:32 AM
JimmyZ06's Avatar
JimmyZ06
I have a Hurst shifter with the C6 **** and like it a lot, at some point i may look at the C6 shifter?
Old Sep 29, 2006 | 11:27 AM
LUCKYC5's Avatar
LUCKYC5
Default MTI six shooter
I have a C6Z shifter but I hear great reviews on the MTI six shooter...might want to check that out
Old Sep 29, 2006 | 05:03 PM
D_K's Avatar
D_K
Navigator
I drove one with an MTI shifter, and it was nice...
I am still trying to decide which I like better myself. Hurst is very short throw.
Old Sep 30, 2006 | 12:10 AM
RobZ06's Avatar
RobZ06
I understand how you feel because I had similiar feelings after a few weeks of ownership several years ago. Here is a non traditional answer, but one for consideration. Confirm a few driver possible issues first. Don't squeeze the shifter, but keep a relaxed grip. Pull back on the shifter from 1 to 2with a few fingers instead of the entire hand. Push up from 2 to 3 with the heel of your palm with a slight pause for the synchros to engage. A relaxed hand technique along with a little more throttle to get rid of the skip shift has increased my driving pleasure of the OEM equipment. Hope this helps and have a great day driving!
Old Sep 30, 2006 | 01:31 AM
Steve Theodore's Avatar
Steve Theodore
At the risk of sounding like a broken record, I think the biggest problem with the C5Z is with the shift **** itself. I switched to an MGW Gripper ****, and I really don't mind the shifter now. It's an even more affordable alternative for you to try...and you can always upgrade the shifter itself later if you want. Good luck!
Old Sep 30, 2006 | 02:56 AM
pb24dagrk's Avatar
pb24dagrk
i went with the new B&M shifter
i had the Hurst originally, and although i loved the throw on it, it made too much noise overall and it rattled my shift **** at wide open throttle (i have the MGW ****)
i ended up trying the B&M and i like it better overall...its not as notchy as the hurst, it doesnt rattle at all either
To shifter questions
