alignment, tire question?
Old Sep 29, 2006 | 10:39 AM
02gt350's Avatar
02gt350
Default alignment, tire question?
Im having an alignment done in the front. My tires are shot in the front and im buying used tires just to get through the rest of the season. If i put used tires on AFTER the alignment, will i need another one, or is this ok?????? They are the same stock sizes
Old Sep 29, 2006 | 10:42 AM
rws.1's Avatar
rws.1
The alignment will affect the wear on the tires. The wear on the tires does not affect the alignment.
Unless you hit a curb or large pothole after the alignment there is no need to re-align after you install the newer tires
Old Sep 29, 2006 | 10:44 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Hi Ryan,
Theoretically when you put the tires on shouldn't matter. To do this right however, you need a 4 wheel alignment - can't get by with a front only on a car with all independent suspension.
Old Sep 29, 2006 | 10:51 AM
Mr.DJ's Avatar
Mr.DJ
, but to also answer your question...
If the used tires are worn evenly, then the alignment specs shouldn't be affected; however, if the tires are worn unevenly to the point where there is no longer an even tread footprint, then this might throw the alignment settings off just a tad.
Last edited by Mr.DJ; Sep 29, 2006 at 10:54 AM. Reason: ~ Grammatical Error Correction ~
Old Sep 29, 2006 | 01:30 PM
02gt350's Avatar
02gt350
Originally Posted by wamara
Hi Ryan,
thanks Wayne, and the rest of you. Gonna see what the problem is in a few hours. and BTW, Wayne, sell the rims?
To alignment, tire question?
