fuel gauge problem
Old Sep 29, 2006 | 11:14 AM
drace99's Avatar
drace99
Default fuel gauge problem
I took a semi-long trip yesterday, and after about 45 minutes of highway driving, the fuel gauge dropped from almost full to completely empty. The low fuel warning came on, even though I know I had a practically full tank. After a few hours of the car sitting, I started her up again and the fuel gauge was fine, showing just over 3/4 full. Again after about 40 minutes of highway driving the same problem occured. Any ideas?
Maybe a ground problem?
HELP!
P.S. Today ok, but I only drive about 10 miles to work.
Old Sep 29, 2006 | 11:16 AM
Chicago's Avatar
Chicago
St. Jude Donor '15
You're probably experiencing what many others have. Get a bottle of Techron and add it to your next tank. The sulphur buildup tends to make the gas gauge go nuts.
Old Sep 29, 2006 | 12:09 PM
drace99's Avatar
drace99
Default Sorry...whats techron?
Sorry...whats techron and where should I get it? The only place that sell auto stuff by me is walmart, do you think they have it?
Old Sep 29, 2006 | 12:15 PM
Lightgomez's Avatar
Lightgomez
Im not 100% sure, but I think that Walmart DOES carry that.
SInce we are on the subject...I ALWAYS gas up at Chevron with Premium grade (which has Techron additives), do I still need to buy a bottle of Techron every once in a while?
Old Sep 29, 2006 | 12:28 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
I'm not sure if Wallyworld has it, but auto parts stores do. It's Chevron Techron. According to their website, Advance Auto has it. Pepboys, Autozone, etc...probably do as well.
Old Sep 29, 2006 | 12:31 PM
I got a bottle of Techron from Wal-Mart. You also might want to switch brands of gas and see if that helps.
Old Sep 29, 2006 | 12:32 PM
RWVH's Avatar
RWVH
Had the same problem . 2 tanks with Techron and the gauge works perfect . The dealer wanted 620.00 to fix , go figure. Bought mine at NAPA.
Old Sep 29, 2006 | 12:48 PM
buckdog06's Avatar
buckdog06
Default You guys are GREAT!
Thanks! just taking a peep on the forum, and Bingo! You all are explaining how to fix the lastest little prob i'm haveing with my '01. At 3 dif. spots on the gage(1/2, 1/3, 1/8) neddle drops to E. Then I have to clear the code while driving, and it pops rite back where it's supposed to be. I'll have to pick some of that up on the way home. Got a Pont. Montana doing it too. Thankyou!
Old Sep 29, 2006 | 03:11 PM
Lightgomez's Avatar
Lightgomez
You are probably have a better chance to find it at an automotive store....Napa, Oreilly, etc. I just got back from Wal-mart about 15 min ago and I looked to see if I could find a bottle of Techron...(Doesnt mean they dont carry, could have been out today, but just FYI.
Good luck on getting it worked out...
How about the question I asked? Does filling up with Premium grade at Chevron exclude us from having to buy a bottle every once in a while?
Old Sep 29, 2006 | 04:32 PM
aficionado's Avatar
aficionado
I'll check what the dealer fixed when I get home.
Old Sep 29, 2006 | 04:48 PM
rws.1's Avatar
rws.1
There are a number of possibilities
1. fouling of sender ... use a good fuel sytem cleaner like Cheron Techron, SeaFoam, Valvoline Synpower or Chemtool B-13
Follow that up with a Brand of gasoline with a beter detergency package
see www.toptiergas.com
2. A bad ground connection
3. a faulty sending unit.
Old Sep 29, 2006 | 09:08 PM
StealthZ06's Avatar
StealthZ06
I have this problem too. Everytime I fill it up the needle goes dead, but sure enough when I get down to about half a tank, it comes right back. I've ran several bottles of Techron through to no avail.
Old Sep 30, 2006 | 09:30 AM
drace99's Avatar
drace99
Default where would I look for a bad ground?
where would I look for a bad ground connection for the gas tank/fuel gauge?
Old Sep 30, 2006 | 10:29 AM
n2zo6stuff's Avatar
n2zo6stuff
I had the same fuel gauge problem lastnite, i'm headed to pepboys for some Techron. I hope this works, heaven knows i don't want to take it to the dealer!!
Damon
Old Nov 10, 2006 | 01:34 PM
buckdog06's Avatar
buckdog06
Still have the fuel guage problem after two bottles to two tanks of Textron. I think I'm going to add it at a higher concentration than what they rec.
To fuel gauge problem
