Service Console Lock??
Old Sep 29, 2006 | 01:05 PM
luv4vettes's Avatar
luv4vettes
Default Service Console Lock??
I took my 2000 to the dealer today to have it looked at for the 'Service Console Lock' message. Thay just called a few minutes ago and said that i need a BCM (body control module). They said it would cost me $550. If i get the CLB, do i need to replace the BCM. I just spent $500 on a new glass top. Money is a little tight. Thanks!
Old Sep 29, 2006 | 01:12 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Sounds like the stealership is trying to take you for a ride. Is it the "service column lock" message? I'd try the CLB first, since it's only fifty bucks. No, you don't need to replace the BCM when installing a CLB.
Old Sep 29, 2006 | 01:17 PM
luv4vettes's Avatar
luv4vettes
Default Yes
Service Column lock Message!
Old Sep 29, 2006 | 01:19 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
stealerships!
Old Sep 29, 2006 | 01:27 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Get your car away from the dealer. Do a search here on the Forum for Column Lock and you'll find a ton of posts concerning this issue. The column lock has been an ongoing problem with many Corvette owners suffering the consequences. GM has had two recalls, but neither has resolved the problem. What is of particular concern about your situation is that the dealer certainly knows, or should have known about this very common problem and the fact there are two well publicized recalls and they are trying to sell you something.
Again, get your car out, read the posts and purchase the Column Lock Bypass. $50.00 bucks and 15 minutes will prevent the problem from ever happening again. Good Luck.
Old Sep 29, 2006 | 01:33 PM
luv4vettes's Avatar
luv4vettes
Default Bcm
They said that the 'BCM' was not covered in the recall or bulletin. Someone please let me know. Thanks.
Old Sep 29, 2006 | 01:46 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
Listen to what everyone is saying....run away from the dealer and order a Column Lock Bypass from Corvettes of Houston or Thunder Racing for about $50. It takes about 30 minutes to install. This will save you from the dreaded column lock!
Old Sep 29, 2006 | 01:52 PM
luv4vettes's Avatar
luv4vettes
Default 1 last question
If it does lock up this weekend. Can i install the CLB and unlock it?
Old Sep 29, 2006 | 01:55 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
I think it needs to be unlocked to install it. Turn the key on shake the wheel hard from side to side, key off, side to side, on, etc... it should unlock. Have the CLB ready to go. Takes no time to install.
Old Sep 29, 2006 | 02:01 PM
thibo's Avatar
thibo
I just had mine done 2 days ago. There is a second recall that came out Feb 8, 2006. It's in effect until 2008. The dealership has to pay for it. Show them this recall they are responsible for fixing it. They will install the Harness Kit, Strg Whl Theft Dtrnt Lk Shorting for free.
http://www.c5registry.com/Technical/GMP0g.htm
Old Sep 29, 2006 | 02:11 PM
timemender's Avatar
timemender
Is your steering wheel locked now? Has it ever actually locked? Order the bypass for $50.00 & install it yourself. Order it next day shipping - if needed ASAP. The sooner the better.
Old Sep 29, 2006 | 02:34 PM
luv4vettes's Avatar
luv4vettes
Default No
It is not locked up yet. My issue is that they are saying that the problem is the BCM (body control module). Not he harness kit, etc.... Does anyone know what else that BCM controls will i run into other issues if in fact that part is bad. Please let me know.
Old Sep 29, 2006 | 03:49 PM
Taxin's Avatar
Taxin
St. Jude Donor '06
go to another dealer
Old Sep 29, 2006 | 04:08 PM
c5BlackBeauty
Lifetime Member
That won't fix the problem. GM discovered after doing this recall, there was a problem with a relay. Get the CLB and be done with this issue.
To Service Console Lock??
