Normal or Abnormal??? -- Pic
Old Sep 30, 2006 | 11:34 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Default Normal or Abnormal??? -- Pic
I pulled the vette out of the garage to give it a bath, opened the hood to blow the dirt out of the engine compartment with the air compressor when I saw the radiator hose was collapsed
Is this normal or abnormal? Engine wasn't warmed up, just ran it long enough to pull out of the garage. I started the car and it did open up again somewhat.
Old Sep 30, 2006 | 11:42 PM
jjvet's Avatar
jjvet
Definitly not normal. I have had this happen on a car long time ago.Can,t remember if bad radiator cap or leak I think cap.
Old Oct 1, 2006 | 12:44 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
ttt
Old Oct 1, 2006 | 12:56 AM
Omega Man's Avatar
Omega Man
From: I speak the truth. Harsh but accurate. The Woodlands Texas
St. Jude Donor '09-'10
Air in the system will cause the hose to do that. The question is where is the air getting in the system? Did you recently change coolant? I would start with the cap and go from there.
Old Oct 1, 2006 | 01:39 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
Have not changed coolant, haven't even opened the cap in the last 8 months or so until just now and I heard a big whoosh of air. Started the car and let sit idling for about 30 min. temp went to 2o5 for a while then 217 for awhile then 226 for a couple minutes then back down to 217.
Old Oct 1, 2006 | 02:26 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Exact same thing happened with "MyVetteDream". Luckily, it was just the coolant tank cap. I think he ended up replacing the hose too.
Old Oct 1, 2006 | 04:07 AM
longrodlx's Avatar
longrodlx
burp the sytem
Old Oct 1, 2006 | 04:22 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by longrodlx
burp the sytem
......burrrrrrrrrrrrrrrp...
To Normal or Abnormal??? -- Pic
