PIAA Questions
Consider the Silverstar from your local autoparts store or Wallyworld.
Direct fit with a noticeable improvement.
Some folks will install the High beam Silverstar in the low beam position. It takes a little modification to the bulb housing.
Also consider the Toshiba 9011 in place of the standard 9006.
Some modification to the bulb housing is needed but easily accomplished.
Here is the link on how to trim the bulb: http://shnu.us/HIR%20Trimming%20Stock.htm
PIAA 1100X -
The PIAA lights draw more current and require a heavier gauge wire harness, which I think is included in the kit. The standard fog light brackets will hold the PIAA lights. An included relay and fuse must be installed to trigger the lights.
The PIAA lights are a great addition. I am really glad I put them on my car.
HTH.
Edit - I just noticed it was my EDN buddy.
I'll be in EDN next weekend, but as usually will probably be pushed for time. I think I still have your number, and if it looks like I got a bit of time I'll give you a ring. I'll have the Vette this trip.
http://forums.corvetteforum.com/show...highlight=Fog+
Randy
http://www.corvettedreams.com/piaa-i.pdf
They are a great mod!...
