Tire pressure sensor ?
Old Oct 4, 2006 | 06:41 PM
tyler77's Avatar
tyler77
Default Tire pressure sensor ?
What is the highest amount of air pressure you can have in your tire that will not set off the DIC warning message. Just had my first set of non run flats put on.
Old Oct 4, 2006 | 06:58 PM
rws.1's Avatar
rws.1
If I recall correctly it is 40 psi
Old Oct 4, 2006 | 07:02 PM
Oldvetter's Avatar
Oldvetter
30 cold is recommended pressure. If you put in much more than that, you will wear out the center of your tires.
26 psi sets off the low pressure alarm.
Old Oct 5, 2006 | 07:02 AM
It is around 40 psi - but no reason to go that high.
To Tire pressure sensor ?
