C5 LED Tail Lights
Old Oct 5, 2006 | 08:31 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Default C5 LED Tail Lights
It is hard for me as a road racer to spend money on non-go-fast parts, but having to replace one lense on the back of the car I decided that the LEDs would be a good choice for the money.
The parts arrive very fast from that aution site. The packaging was good and at first I thought that there was a scratch in one of the lights then I realized that each light was wrapped with plastic. removed the plastic and the lights were perfect.
Installation was relatively easy. Take the old ones out, remove the light bulb, clean the contacts, insert the LED light harness to the C5 harness. I am glad that I tested all the lights before putting it all back together. One of the lights worked with the brake, but not with the flashers. I pulled the harness and turned it over and it worked fine .
I also thought that with the turn signal on the LED blinked way too fast. I then read the instructions that they need the car to be started to blink at normal speed. I guess they take a bit more power than the stock ones to run. Anyway I started the car and they were fine.
One change I made to the car was removing the flush mounts. I liked the flush mounts with the stock lights, but I thought the LEDS looked better set inside the housing.
the results are great. Man they are bright compared to the stock ones. I assume people will be able to see me now.
I have the PIAAs coming in this week and I am on the fence with the HIDs, but I think the more light the better.
Old Oct 5, 2006 | 08:33 AM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
Great mod.
Old Oct 5, 2006 | 08:37 AM
RTSVET's Avatar
RTSVET
The leds are on my list to do soon also since they are at such a good price on that auction site HA HA show us some pics.
Old Oct 5, 2006 | 08:44 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
I've got the LED taillights on my short list also. I kind of went the other way around and decided to do the front first. Placed an order with Nate at Corvette Garage for the HIDs. Once I get that done, the LED taillights will probably be next. So where are the pics?
Old Oct 5, 2006 | 08:50 AM
Wicked Weasel
I took some pics last night, but didn't have time to post
I will post tonight. I took some pics of the packaging too so people can see that they are just not thrown together and sent out.
Old Oct 5, 2006 | 08:51 AM
Wicked Weasel
any word when Nate will have them in???
Old Oct 5, 2006 | 08:57 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Last I heard was early next week.
Old Oct 5, 2006 | 10:20 AM
jdmvette's Avatar
jdmvette
Night Owl for life
LEDs & HIDs =
Old Oct 5, 2006 | 10:46 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Bob, it is a power mod, LEDs use less current then filament bulbs, therefore less parasitic draw on the alternator = more RWHP. Also it is good for safety, LEDs light faster and they are brighter.
Old Oct 5, 2006 | 10:57 AM
Wicked Weasel
I guess if the hood seal is considered a hp mod so should the LEDs
BTW - thanks for all the help with getting this light package together. Seeing your car was the deciding factor....
To C5 LED Tail Lights
