BSMs
Old Oct 5, 2006 | 04:35 PM
BayVette's Avatar
BayVette
Default BSMs
My car came with body side moldings, I think it would look better without them, is it possible to remove them and not leave glue behind?
Thx
BayVette
Old Oct 5, 2006 | 04:44 PM
Hrdtop00's Avatar
Hrdtop00
Yes, you can remove. Most here use monofilament fishing line and a hair dryer to remove BSMs. Then remove the glue, wax, and you're done. Do a search of CF, there are tons of threads discussing this.
Good luck.
Old Oct 5, 2006 | 04:46 PM
Tom/99's Avatar
Tom/99
Good luck.
Old Oct 5, 2006 | 05:15 PM
BJ-99's Avatar
BJ-99
Default remove side mldgs
I have a better solution. Go to an auto paint shop. Get 3M adhesive remover (about $12) soak the BSM from the top. Use a teflon kitchen spatula to lift the BSM & keep adding 3M. getting the residual adhesive is the worst part. You can roll most of the adhesive off with you thumb. I finished by using my circular buffer. I did it this way. 35 minutes to remove the BSM 2 hrs to get the adhesive off the car.
Old Oct 5, 2006 | 05:27 PM
Lots of people have removed them using the hair dryer/fishing line technique.
Old Oct 5, 2006 | 05:30 PM
Vega$Vette's Avatar
Vega$Vette
Been there done that. Fishing line and Googone.
Old Oct 5, 2006 | 05:35 PM
Vassili's Avatar
Vassili
DO IT NOW - You'll love the look, it was the way the engineers envisioned the car to be.
gdphillipsvette's Avatar
gdphillipsvette
Done that too - fishing line, hair dryer and very sore thumbs! Top off the job with WD-40 or 3M adhesive remover; then rewax the doors.
Gordon
Old Oct 5, 2006 | 05:39 PM
hotwheels57's Avatar
hotwheels57
...ahhhh, rolling double sided tape off with your thumbs. I've gotten some of my best blisters doing that...
I think it's 3M that makes a hand drill attachment disc that supposedly will remove decals/adhesive etc w/o paint damage...sounds to good to be true so I continue to burn off my thumb prints...
To BSMs
