How do you fix carb rash
Old Oct 9, 2006 | 08:12 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Default How do you fix carb rash
I did a couple searches and didnt find what I was looking for.
I thought I saw a thread a long time ago, but I cant find it. I have some curb rash, and Im due for some tires, so Id like to try and fix it some. Im budgeting for new rims, so If it doesnt work, that's ok.
Old Oct 9, 2006 | 08:50 AM
cam99's Avatar
cam99
Take them to a competent wheel shop.
Old Oct 9, 2006 | 08:54 AM
hardtop's Avatar
hardtop
Apply a liberal dose of hydracortizone to the affected carb and stop using cheap gas.
Old Oct 9, 2006 | 10:12 AM
phils C5 vette
cam99 Take them to a competent wheel shop.
What part of the post did you miss where it says "Im budgeting for new rims, so If it doesnt work, that's ok."
Old Oct 9, 2006 | 10:24 AM
IDM's Avatar
IDM
what is the finish on your wheels?
if they are polished it's easily repairable unless there is too much metal missing
get rid of the roughness with sand paper...start from around 100 grit and finish off with 400 grit, then use some polishing cream
Old Oct 9, 2006 | 10:33 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I fixed some rash on my polished aluminum wheels by using a 3M sandblaster. I got it at Lowe's. It is a 380 grit sponge that molds to the shape of the wheel. I then used it to sand the rash out followed by aluminum polish to remove the fine scratches left behind. It worked pretty well.
Old Oct 9, 2006 | 01:15 PM
GUSTO14's Avatar
GUSTO14
Contact these folks and ask them...
Ye Olde Wheel Shop, 6363 Washington Blvd., Elkridge, MD 21075, (800) 526-8260, (410) 796-8400
They have been in business for many years and are not too far from you. They should be able to give you an idea of what needs to be done.
Good luck... GUSTO
Old Oct 9, 2006 | 03:41 PM
pjm710's Avatar
pjm710
stop hitting it with out protection and you wont get the rash
Old Oct 9, 2006 | 03:43 PM
phils C5 vette
The rims are the polished Y2K rims. The curb rash isnt to deep and a couple inches long. I pretty sure the rims have a clear coat on them also
To How do you fix carb rash
