Black outs
Old Oct 9, 2006 | 08:31 PM
TJ VETT's Avatar
TJ VETT
Default Black outs
Has anyone installed black outs (dark pexiglass ones) on the front lights? My question is do you have to unbolt the whole light assembly or is there a trick to somehow slide the plexi pieces between the lights and the car? TXS Tom
Old Oct 9, 2006 | 11:43 PM
DirteeDave's Avatar
DirteeDave
I was able to slide mine in carefully.
Old Oct 10, 2006 | 12:16 AM
dreamscometrue's Avatar
dreamscometrue
They slide in but it takes a little convincing. I put masking tape all around the area to protect the paint then slide the back of them in first and "poped" the front part in. I did it very slowly because I did not want to crack them but I think they are pretty strong and will flex a good amount to get them in place.
Good luck!
Old Oct 10, 2006 | 12:17 AM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
slid mine in too But i would venture to guess what this depends on the blackout kit
Old Oct 10, 2006 | 01:49 AM
blackwithyellowta's Avatar
blackwithyellowta
Get them painted, hopefully I will be recieving mine next week from Richard (C5VetteLS1) -Corvette Enhancements. He has been very helpful and cooperative. I'm getting the black fascia too.
Old Oct 10, 2006 | 02:14 AM
Brabus2's Avatar
Brabus2
That's one wicked looking C5.
Old Oct 10, 2006 | 04:23 AM
MEXAKNPWR's Avatar
MEXAKNPWR
i just slid mine in 5 minutes ago.
take the corresponding side and begin by forcing the thinner end in an up right manner. if you look, there is actually a lil gap at this top right corner of the driver's side front marker and rop left corner of the passenger side front marker.
when you get that in, follow along the top rim of the blackout piece and push it in following the gap that runs along the top of the marker. it is at this point in which you will reach the fatter side.
the fatter side can slide in by basically wedging it in. it will bend but the plexi is actually strong and will bend accordingly. smooth it under the lip with your fingers pressing firmly and you will hear a pop. then you will notice that it went it.
to secure the fit better, wedge the bottom down with your fingers in order to get the plexi to cover an even spread all along.
this should take you 2 minutes a side.
To Black outs
