Motor Update 2
Old Oct 10, 2006 | 09:03 AM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
Default Motor Update 2
In case you didn't remember... i have a c5R 427 built by MTI. rings were washed out, timing chain had .5" slop, 3 valves bent, bearings bad, heads had holes in it...all resulted in oil consumption at an alarming rate of 1qt/200 miles. my intake had about .5" of sludge in it, no joke! all this and it still made 478rwhp.
so i pulled the motor with a buddy in 10hrs. Drove over to DRM, had them rebuild it to be mint! Now, in the process of getting it back in.
My buddy who has been helping me has been busy, so i can only work when he could. But last night, i took a brave stand and worked for 5 hrs myself. heres the latest! everything is on EXCEPT the radiator, condensor, trans cooler, and brake booster. so basically lil lines to run.
We had got a lot done on sat, but then i noticed two tranny cooler lines sittin on the floor. they needed to go under the engine, but above the subframe. i couldn't fish it thru, so guess what, had to drop the entire subframe to get it in there!!! i was !!! but really, all it takes is unbolting the shocks towers, the control arms, the sway bars, then undo 6 nuts for the craddle, and she drops... not as bad as it sounds.
Going to work on it tonight and do start up. wish me luck boys!!!
Aj
Old Oct 10, 2006 | 09:11 AM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
Good luck in getting it back together, but where are the pics? I would like to see all this work being done.
Old Oct 10, 2006 | 09:20 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
We need pics mang!
Old Oct 10, 2006 | 11:08 AM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
haha..pics will come when i get it all compiled later... been very busy at work... being a mechanical engineer by day and a automotive engineer at night REALLY takes it out of ya! LOL. thanks for the support!
Aj
Old Oct 10, 2006 | 11:09 AM
Dark-Knight's Avatar
Dark-Knight
Geeze! How did your motor get so messed up?
Old Oct 10, 2006 | 02:21 PM
Best of luck getting it all bolted back together.
Old Oct 10, 2006 | 02:48 PM
edensknight's Avatar
edensknight
Whoa! What a personal awesome effort! You are doing an outstanding job! Keep us posted!
Old Oct 10, 2006 | 02:50 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
one word.... MTI
apparently, myself and a few others have motors built by MTI when they used bad quality rings. On top of that, the holes in the heads were b/c who ever ported it, did way too much on the intake side and drilled into some oil passage. Then, covered it with epoxy. the springs were too strong so it cracked the epoxy. i have only put 10K miles on this motor, but it has 12K total from previous owner. a NEW motor should not be like this, so im assuming it was a crap build from the beginning.
thanks again guys, will keep you updated!
Aj
peter pan's Avatar
peter pan
Life Time NCM #2196
Great to hear some good progress and get those pictures up
Old Oct 10, 2006 | 04:52 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Old Oct 10, 2006 | 04:56 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Good progress. Good luck with start-up!
Old Oct 10, 2006 | 04:57 PM
TonyC5's Avatar
TonyC5
AJ- Best of luck finishing her up!!!
To Motor Update 2
