Please advise regarding Heads
Old Oct 11, 2006 | 03:40 PM
vmaquera's Avatar
vmaquera
Default Please advise regarding Heads
I have an LS-6 engine. I am torn between porting, polishing and shaving the stock heads, vs getting AFR 205s.
Any comments would be greatly appreciated.
Old Oct 11, 2006 | 07:35 PM
spiral04's Avatar
spiral04
I'm interested in the same thing. Here's a bump for ya!
Old Oct 11, 2006 | 09:39 PM
bennettrp's Avatar
bennettrp
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
I'm about to install the afr 205's. Along with LG's g5x3 cam. With this vehicle, no sense screwing around with shortcuts.
Old Oct 11, 2006 | 09:46 PM
Vega$Vette's Avatar
Vega$Vette
It all depends on what your goals are for the motor. If you're look for 450 +- you don't need to spend the $ on AFRs Approx. $2400. You can do Patroits that have #s very close to AFR's for 1/2 the price or have a good shop do yours for $800 - $1000
Old Oct 11, 2006 | 09:54 PM
Old Man in a C's Avatar
Old Man in a C
Originally Posted by vmaquera
shaving the stock heads.
Shaving the heads? I take it that's all about compression ratio. How many thousandths would you remove, and what ratio would you end up with? Educate me.
Old Oct 12, 2006 | 12:15 AM
Mpwr's Avatar
Mpwr
What kind of power should you be making after this work is done?
To Please advise regarding Heads
