wheel rollout
Old Oct 11, 2006 | 05:13 PM
stlchevy97's Avatar
stlchevy97
Default wheel rollout
i put 18x12's rear and 18x9.5 front wheels on and a while ago and since i put them on my traction control is acting up. when i get above 20 with t/c on it bogs the car down like my tires are spinning. i took it to the chevy dealer and they said its because the rollout has changed and there was nothing they could do for me. there has to be something that can be done. alot of vette owners get aftermarket wheels. any suggestions? thanks,
casey
Old Oct 11, 2006 | 05:36 PM
Y2KVert's Avatar
Y2KVert
St. Jude Donor 06
casey
Hit the little button on the console and turn it off.
Old Oct 11, 2006 | 06:25 PM
Darion's Avatar
Darion
The issue is most likely not the wheel size it is probably the tire size. What size tires do you have mounted to your new wheels?
Darion
Old Oct 11, 2006 | 06:35 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Darion
What size tires?
Old Oct 11, 2006 | 06:37 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Many people run 18's front and rear ( width means nothing ) Tire height is the problem... you need .075 in. to 1.00 in. height variation from front to rear, Naturally the rear's have to be higher this is done by chosing ther proper aspect ratio to achieve this offset.
Old Oct 11, 2006 | 06:50 PM
Darion's Avatar
Darion
rws.1's Avatar
rws.1
E-T ( as always) has it correct.
Old Oct 11, 2006 | 07:06 PM
rtsb's Avatar
rtsb
I was wondering why they come like 17 on the front and 18 on the back
can you explain what you mean by proper aspect ratio?
Old Oct 11, 2006 | 07:17 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Aspect ratio alone has nothing to do with it, since it is affected by width. It is possible to put a 30 series tire on that is taller than a 35 series, so who cares what the aspect ratio number is.
Pay attention to the overall height (diameter) of the tire, that's all that matters.
Old Oct 11, 2006 | 08:19 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Old Oct 11, 2006 | 08:38 PM
stlchevy97's Avatar
stlchevy97
right, i do turn it off. but im selling so i can buy a house and pay off some debt so i would like traction control to work for the next owner. my tire size is 335x30 18
Old Oct 11, 2006 | 08:40 PM
stlchevy97's Avatar
stlchevy97
275x40 18 in the front. thats probly the issue the difference in the profile but is there any fix for that besides buying 275x30's
Old Oct 11, 2006 | 08:46 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
That's your problem...the front tires are ~ .6" taller than the rears.
You have to keep the front tires shorter to avoid such issues.
276/36/18 will probably work for you, a 265/35/18 would be better in terms of front/rear tire height ratio..
Either live with turning the T/C off at startup, or get the shorter front tires.
Old Oct 12, 2006 | 07:42 AM
Darion's Avatar
Darion
Yup, thats it. Should be able to sell the 275/40-18 being that size is stock for coupe rears.
Darion
Old Oct 12, 2006 | 04:39 PM
stlchevy97's Avatar
stlchevy97
thats true. thanks for all of your help. ill post in the parts for sale.
To wheel rollout
