Halo LED tail light install problems.
Old Oct 11, 2006 | 05:55 PM
MixZ06's Avatar
MixZ06
Default Halo LED tail light install problems.
Ok, so now I'm having problems installing my Halo LED tail lights. (I am also having problems installing my 9005 PIAA bulbs )
The outer LED lights fit perfectly, it's the inner lights that I am having problems with. They do not fit into the slot perfectly (both sides). It looks as though the piece that holds the brake light wires is in the way. Yes, I am putting the tail light marked with an "L" on the left side. Heck, I even tried switching them and they would not go in.
Just wondering if anyone else has experienced this? I haven't read anything about anyone running into a similar problem. Perhaps this is not an OEM bumper?
It seems that the simplest of mods are giving me the most headaches.
Old Oct 11, 2006 | 06:11 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
is it upside down that would make the tail light wire be in the way - dont ask me how I know that
Old Oct 11, 2006 | 06:23 PM
MixZ06's Avatar
MixZ06
Nope, right side up. The "TOP" written on the back is on the top.
I actually checked that many times because I am fully capable of screwing that up.
Old Oct 11, 2006 | 06:36 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Strange. Mine went in without a problem. Maybe they mismarked a left for a right or some such thing.
Old Oct 11, 2006 | 06:38 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
With one of my inside lights I had to finagle it in a little bit, but it was not a big issue.
Old Oct 11, 2006 | 06:44 PM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
I had to mess with mine a little also to get them to fit right....but it was easy to do Good Luck
Old Oct 11, 2006 | 07:14 PM
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
Same here on both inside lights. I had to remove the clip that holds the wires in place. Took a bit of a push to get it to seat flush, but all's well now. I know from working with our exhaust fascia overlay that no two rear fascias are identical. Even 2 new fascias won't be mounted the same on 2 different C5's. So some will fit perfect, and others will not. You might try some soapy water with a slight push to see if you can slide it in place.
Best of luck,
Richard
Old Oct 11, 2006 | 07:29 PM
MixZ06's Avatar
MixZ06
Best of luck,
Richard
Interesting, thanks a lot.
Glad to know that others have seen this. I might just take a hacksaw to the little piece and saw it off.......it appears to only hold the wires up.
Old Oct 11, 2006 | 07:58 PM
PolishDude's Avatar
PolishDude
mine just went right in
Old Oct 11, 2006 | 08:12 PM
MixZ06's Avatar
MixZ06
Ok, I switched them, and they seemed to fit correctly....with a little persuation. I am just wondering now if there is any downsides or reprecussions to putting the wrong one's on either side?
Yes, I was very careful to make sure I had it correct in the first place. So now I have an "L" on the outside left and an "R" on the inside left, vice versa on the other side.
Hopefully all goes well.
Old Oct 11, 2006 | 08:39 PM
stevetas's Avatar
stevetas
I had the same problem. I switched the inside Right, to the inside Left, & the inside Left, to the inside Right. Everything work's fine now.
Old Oct 11, 2006 | 08:40 PM
jdmvette's Avatar
jdmvette
Night Owl for life
you might have to clip just a bit of the facia where the tails are screwed in. it's no big thing and that part will never be seen or missed.
Old Oct 11, 2006 | 09:51 PM
double-oh-coupe's Avatar
double-oh-coupe
That's exactly what I did ...
Old Oct 11, 2006 | 09:58 PM
C5VetteLS1's Avatar
C5VetteLS1
It shouldn't make any difference at all. They're all wired the same and serve the same functions. Good for you, glad it worked out
Richard
Old Oct 11, 2006 | 10:03 PM
MixZ06's Avatar
MixZ06
I still might take a dremel to the little piece inside and switch the lights back to their proper side. Although they fit in the opposite side, it is not perfect.
Thanks everyone.
Old Oct 11, 2006 | 10:19 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Richard
still waiting for your pics.
Old Oct 12, 2006 | 01:29 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
Same problem here,it seems the holes are drilled alittle off from the factory.
To Halo LED tail light install problems.
Old Oct 12, 2006 | 02:55 PM
C5VetteLS1's Avatar
C5VetteLS1
Alright, alright ... here's mine Really not much to see ... until they're lighted ... then there is plenty to see. Our tests proved successful in blacking out the LED's. They're MUCH brighter than blacked out OEM's ... And nearly as bright as standard bulbs in the stock red OEM housing. We'll soon be offering the brightest black outs available. They are awesome Unfortunately it's very hard to have the comparisons show effectively in the photos.
Richard
Old Oct 12, 2006 | 03:08 PM
MixZ06's Avatar
MixZ06
Whoa, sweet pics! Those blackouts sure look nice on that Silver Z.
It bothered me SOOOO much that I had the tail lights on the wrong side, that I decided to just go down and saw off those pieces. After some apologizing to the car that I cut her, the tails went into their respective slots on the correct side with no problemos.
Sorry about the pics, I will get some up in the near future.
Old Oct 12, 2006 | 03:53 PM
IDM's Avatar
IDM
I had to cut the tabs on mine for the inside ones to fit...I just cut enough where that black pin that holds the wiring harness still has a hole to go into, others have done the same
