[Z06] Drain Petcock help
Old Oct 14, 2006 | 10:49 AM
Steve Zaino's Avatar
Steve Zaino
Default Drain Petcock help
2003 Z06
Ok I'm trying to open the drain valve at the bottom of the radiator to drain the system and install a new thermostat.
What tool do you use to open this little piece of brittle plastic which I am now starting to chew up. I have been able to turn it counter clockwise ever so slightly and thats it.
I've tried a flat head on the inside rectangular opening and a plyers on the outside of the entire piece.
Old Oct 14, 2006 | 11:12 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
I use the 1/4 inch socket tool in my socket wrench kit. It's the tool that looks like a screwdriver, but has a 1/4 inch head to mount small sockets.
The petcock only rotates 1/4 turn counterclockwise. Then use needle nose pliers to pull the thing out.
Don't over-torque on the way back.
Karl
Old Oct 14, 2006 | 11:29 AM
Steve Zaino
Thanks, I got it out with needle nose plyers, one end in the center hole the other end on the outside, wiggle and turn.
Do you know how many foot pounds the thermostat housing should be tightened to?
When removing the old one, I barely hand to turn the socket and they loosened right up.
Old Oct 14, 2006 | 02:07 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Originally Posted by Steve Zaino
.Do you know how many foot pounds the thermostat housing should be tightened to?
Here ya' go, this may be of some help:
http://www.metricchemical.com/C5torque.pdf
Old Oct 14, 2006 | 06:53 PM
Steve Zaino
Thanks for the torque ref list.
Got my new thermostat in ok and seems to have cured the overheating problem.
To Drain Petcock help
