Part Numbers
Old Oct 15, 2006 | 03:32 PM
VETSTYL's Avatar
VETSTYL
Default Part Numbers
Does anyone have the part number for front 2004 Z06 sway bars? Correct me if I'm wrong. I have a 2000 C5 Vert; is the rear sway bar the same size as the 04 Z06 sway bar?
Old Oct 15, 2006 | 07:41 PM
GrayC5's Avatar
GrayC5
Shaft, Front Stabilizer (FE4) GM # 10419094
Shaft, Rear Stabilizer (FE3*, FE4) GM # 10424743 (* Model year 2000 and later)
(NOTE: These are the latest part numbers of which I'm aware. However, part numbers do change and you may want to check with your dealer to insure these are the most current.)
Depends on which suspension your car has now. If it is equipped with the model year 2000 or later Z51/FE3 Sport Suspension, then yes the rear sway bar should be the same as for the Z06/FE4 suspension. If your car is equipped with the FE1 Base Suspension or the F45 Selective Real Time Damping System, then no they are not the same.
Also, don't forget the sway bar bushings. Too, depending on the suspension and end links your car has now, you may need to upgrade to the aluminum end links.
The following Forum supporting vendors will usually have or will put together a package to meet your specific needs. Also, they may well have some of the best prices on new parts:
Fichtner Chevrolet
Parts Manager: Bob Wendorff
800-234-5284
E-Mail: parts@fichtnerchevrolet.com
Fred Beans Buick Pontiac GMC
Parts Manager: Gene Culley
610-495-1700
E-mail: gculley@fredbeans.com
HTH
