Installing Shift Boot
Old Oct 15, 2006 | 05:09 PM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
Default Installing Shift Boot
For those of you that have installed aftermarket shift boots on an A4, what type/brand of glue did you use to secure the leather inside the plastic surround ?
Old Oct 15, 2006 | 06:47 PM
EMS19's Avatar
EMS19
Default shift boot install
Vette Essentials has a nice set of step by step instruction. I did not see any mention of glue though.
http://www.vetteessentials.com/instr...t_install.html
Old Oct 15, 2006 | 06:52 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Vette essentials sends it with the boot already attached to that piece.
I'd use 3m spray adhesive(Lowes etc. ) and spread it with my finger if I were doing what you need done.........
Old Oct 15, 2006 | 07:12 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Old Oct 15, 2006 | 07:38 PM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
Thanks guys. I went with the Redline product due mostly to getting them from a forumn member at a very nice price. If I can do it cheaper, and get good results, thats the route I will go (unless were talking a safety issue, then it's a no holds barred situatuion).
After researching and applying some common sense, I bought some epoxy and it is working like a champ. It's not a fast process. Mix a little, apply, let set, repeat ... Almost complete...
Old Oct 15, 2006 | 08:35 PM
TJ VETT's Avatar
TJ VETT
I used gorilla glue and that job was a pain , definitely need patience
Old Oct 15, 2006 | 08:40 PM
frodo84's Avatar
frodo84
Uneducated autodidact
Okay, what brand epoxy, and where did you get it? Thanks!
Old Oct 15, 2006 | 09:13 PM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
I used PermaOXY branded by Permatex. Bought it at a local autoparts store...
Finished pics... I think it turned out nice...
Old Oct 15, 2006 | 09:28 PM
ALLEGRO's Avatar
ALLEGRO
VetteEssentials for me. No hassle at all intalling......no glue !
Old Oct 16, 2006 | 11:14 AM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
Yup, no glue required for manual...
To Installing Shift Boot
