[Z06] HELP. Differential noise/questions...
(Just found the thread where I read that. "Differential Gear Oil" "I have just checked the bearings on other cars by jacking it up and then trying to rock the wheel back and forth. Usually one hand on the top of the wheel and one on the bottom. If it moves, then the bearing is probabaly going").
I checked this after I've noticed some light chattering from the rear of the car over the last few days.
I only notice it after I just start driving and do a u-turn or after the car has cooled down and I do a u-turn. I've done the figure 8s after driving a while and no noise.
I switched to Royal Purple at 6K and now have 10K. No noise until now. Should I add an ounce of the GM additive and keep adding an ounce at a time until the noise is gone? Is the play normal?
Thanks for any help.
If I remember correctly the max tolerance for the wheel bearing is .005" and .125" for the ball joint at the spindle.
