jacking question!
Old Oct 17, 2006 | 01:33 PM
jimbosr's Avatar
jimbosr
Default jacking question!
hi all, i just bought a low clearance jak and 4 jack stands. where do i lift the rear and the front of the car at .and where do i put the stands at? i dont trust the stealership to change the oil sooo will do it myself. thanks in advance........jim
Old Oct 17, 2006 | 02:12 PM
LV_2_XLR8's Avatar
LV_2_XLR8
I use Rhino Ramps to get the front high enough to slide my low profile jack under the front cross member. The jack fits just fine under the rear crossmember without the Rhino ramps. Then, I use a 2 foot 4X4 to equalize the weight distribution along the crossmember. I've read horror stories about the crossmembers cracking if you lift them in the middle.
Then I use jack stands at the slotted lifting points along the frame rails to shore the car up.
I'm sure other use different methods, but this works just fine for me.
Old Oct 17, 2006 | 02:40 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
This should get you some answers. http:www.zo6vette.com/dyilift.php If not www.zo6vette.com "dyi lifting your c5 without pucks"
Old Oct 17, 2006 | 07:16 PM
jimbosr's Avatar
jimbosr
thanks guys, the front seams to have 2 crossmembers. 1 in front of the oil drain plug and 1 forward of that. would i jack up the one most foward wright? thanks again......jim
Old Oct 17, 2006 | 11:49 PM
General Lee's Avatar
General Lee
Thats how iv done it in the past
Old Oct 18, 2006 | 09:35 AM
LV_2_XLR8's Avatar
LV_2_XLR8
The one I use is the one that ties the suspension components together.
To jacking question!
