Tire Pressure Indicator :
Old Oct 19, 2006 | 02:00 PM
daddyrich's Avatar
daddyrich
Default Tire Pressure Indicator :
For about two weeks, when I first start driving my C5, my tire pressure indicator gauge states I have low tire pressure. I know for a fact that is not the case. Outside air temp is not a factor. So I do the reset deal and all is cool till I start and go agin. Today is the first time I have had a little time to research the problem on the forum. Can anyone enlighten me whereas this is a easy fix or a dealer repair. B][/B]
Old Oct 19, 2006 | 02:11 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
so what is your cold tire pressure as measured by an external guage? There is no method I know of to recalibrate the pressure sensors in terms of what they read for PSI. They have been known to be somewhat inaccurate but are usually consistant.
Old Oct 19, 2006 | 02:13 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
if the sensors need to be replaced you need to pop the tire loose to get at them. A dealer is not required, but a tire machine is...
Old Oct 19, 2006 | 02:15 PM
jrose7004's Avatar
jrose7004
I imagine that your battery on the sensor is starting to go!
Old Oct 19, 2006 | 04:30 PM
Don't know how old your car is, but it could very well be that the sensors are acting up. The life of a sensor is usually anywhere from 5-8 years or so.
Old Oct 19, 2006 | 04:43 PM
daddyrich's Avatar
daddyrich
Just checked my owners manual and I didn't see a reference for location of a battery for such sensor or it's location. Where do I get access to the sensor and the battery. tks
Old Oct 19, 2006 | 05:09 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
the sensor is mounted inside the wheel. The only part of it you can get at is the valve stem. The battery is inside each sensor.
Here's a pic of one style -
PS - the batteries are not designed to be user replaceable...
Old Oct 19, 2006 | 05:26 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
What year is your car, and what is the pressure of the tire/tires when this low tire pressure reading occurs...
Old Oct 19, 2006 | 07:10 PM
daddyrich's Avatar
daddyrich
2000 and low pressure states 23 to 24 most of the time.
Old Oct 19, 2006 | 07:14 PM
Oldvetter's Avatar
Oldvetter
At 26 psi you will get a low pressure warning. Your tires need air !
Old Oct 19, 2006 | 07:30 PM
daddyrich's Avatar
daddyrich
No my actual pressure is 29 pounds , it just regesters that low on my gauges, inaddition the temp outside is has been 75 deg. and it states this temp after tires are warm. I have to replace my batterys best I can tell. Thanks for everyones input.
Old Oct 19, 2006 | 10:37 PM
Evil-Twin's Avatar
Evil-Twin
your 2000 TPS are 7 years old and reaching their life's end.... dont waste your time or money trying to replace the batteries...
You need four new sealed sensors... dont buy off Ebay...
Buy New Genuine GM sensors... they list for 120 dollars each but you can get them from Gene Culley at Fred beans for around 75 follars each..
Gene Culley
Director of Internet parts sales
Fred Beans of Limerick, Pa
40 Auto Park Boulevard
Limerick, Pa 19468
610.495.1700
gculley@fredbeans.com
Old Oct 19, 2006 | 10:53 PM
Black94LT1's Avatar
Black94LT1
Cruise-In 10-11-12 Veteran
St. Jude Donor '09-'10-'11-'12-'14
I just got a set from Fred Beans a few days ago. Waiting for the wheels to arrive, and then off for tires for the 99!
To Tire Pressure Indicator :
