problem with lowerd car....?
Old Oct 20, 2006 | 07:00 PM
omarcoolguy's Avatar
omarcoolguy
Default problem with lowerd car....?
I lowerd my c5 a month ago.......i lowerd the stock bolts....and cut off 2/3s the bushshing......now my car squeaks alot at slow speeds ( accel. and going over speed bump and drive ways) ive sprayed wd40---lithium grease.....and a few others under there......but it seems to only work for a few days or weeks.....then wen i wash it or it rains its starts acting up......i dont wanna raise it up i like it that low.....any help?????
Old Oct 20, 2006 | 11:09 PM
Say'n Somthin's Avatar
Say'n Somthin
I had the same problem but I put the longer bolts in the rear and have the polyurethane bushings. The squeaks seem to have come from the rear. I sprayed some white lithum grease on the rear bushings and it seem to work so far. I lubed them up pretty good too. You may have to do this a couple times to get the grease seated good enough.
Old Oct 21, 2006 | 01:09 AM
omarcoolguy
thanx......mines comeing from the front....i geuss ill check them tomarrow.....im putting my new wheels and tires on .....they 18-19 so i might have to raise it up a lil ne way
Old Oct 21, 2006 | 09:40 AM
Say'n Somthin
I do not have any bushings in the front. That may be why it is not squeaking up there. I put CCW 19" all the way around. Nothing like pulling up somewhere, in a nice corvette, and having this awful and embarrassing squeaks coming from under the car. Good Luck!
Old Oct 21, 2006 | 12:22 PM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Where "under there" are you spraying? Have you determined exactly where the squeaks are eminating from?
A lot of times squeaks coming from the front of the car are from the sway bar bushings. Evil-Twin had a write up (can't find it atm) that went through the procedure of removing the bushings, cleaning off (sanding?) the area where the bushings make contact with the sway bar, spray painting that area, and then lubing the bushing contact area when re-installing the bushings.
Old Oct 21, 2006 | 01:06 PM
rgtkst's Avatar
rgtkst
have you checked to make sure that the cut bushing has not allowed the bolt to come thru and sit directly on the spring???
Old Oct 21, 2006 | 02:21 PM
omarcoolguy
ive been spraying the bolt where the bushings are......when i orig. cut the 2/3 of it i grinded down the the sides to make sure it was smooth ....it almost sounds like metal touching metal.....i have a prof. mech. doing the mods.....he thinks we should just ad a rubber washer on top and grease the hell out of it im still not sure wat to do.....?
Old Oct 21, 2006 | 03:19 PM
jaxgator's Avatar
jaxgator
St. Jude Donor '07
Well, if it's metal on metal then it sure wouldn't be the bolt on the spring as the springs are not made of metal.
Old Oct 21, 2006 | 03:33 PM
photoguy's Avatar
photoguy
Can you spell corvette?
Old Oct 21, 2006 | 07:13 PM
Sick Z06's Avatar
Sick Z06
Man i can't stand people that type like that. Or use Do' as though.
First off, ditch the WD-40 and lithium lube CRAP. WD-40 is "Water Dispersant, recipe #40" That's not going to help you at all. you have a friction sqeak.
Try using "Graphite" or Moly lube, and as recommended check the bushings to make sure they didn't rub through.
Old Oct 21, 2006 | 07:33 PM
omarcoolguy
Thanx for the input I have to wait untill next week to check everything its raining all weekend...(chicago) and i just spent 4 hours detailing the thing so ill let u guys know.....any more suggestions are appreciated....and sorry to the grammer teachers i type fast and dont really care if anything is spelled wrong. lol
To problem with lowerd car....?
